Ultra96 Hardware Design Simple build fails (tutorial #1)
  • Subscribers 365 subscribers
  • Views 414 views
e14 Contributor over 8 years ago
Hi All,
I'm running through the tutorials, starting with #1 which is basically a test that Vivado is installed correctly. (apparently it isn't :-)
Everything in the tutoral works like it should until I get to the step that says "Generate Bitstream", at that point it says "There were errors" and it gives me a choice of opening messages or logs.
There are a lot of messages and most seem pretty innocuous. 111 Info, 238 warning, and 85 status.
The last status seems to be Starting synth_design ... synth_design completed successfully.
I can't figure out where the error is.
Edit: So after a lot of variation it seems that for some reason the implmenetation step fails if my project directory is a mapped network drive. Really Xilinx? Network attached storage has been a thing for over a quarter century now. Is this a known bug in 2018.2? When will it be fixed?
--Chuck
  • jafoste4
    0 jafoste4 over 8 years ago
    Hi Chuck,
    Since I have been working with the Xilinx tool set, this has always been an issue. Vivado is very particular to the directory you set it to. For more information, My suggestion if you want an official response would be to ask Xilinx on this matter.
    -Josh
