Ultra96 Hardware Design clear internal flash
  • Subscribers 364 subscribers
  • Views 391 views
maxim.uvarov@linaro.org
maxim.uvarov@linaro.org over 8 years ago
Will Ultra96 boot if internal flash cleared?
Boards boots without SD card. And even with SD card it always boots from internal memory. If I clear it will board dead it it will boot from external SD card?   cat /dev/zero > /dev/mmcblk0?
  /dev/mmcblk0p1  131072   131075        4    2K unknown
  /dev/mmcblk0p2  131076   132099     1024  512K unknown
  /dev/mmcblk0p3  132100   133123     1024  512K unknown
  /dev/mmcblk0p4  133124   135171     2048    1M unknown
  /dev/mmcblk0p5  135172   136195     1024  512K unknown
  /dev/mmcblk0p6  262144   262175       32   16K unknown
  /dev/mmcblk0p7  262176   264223     2048    1M unknown
  /dev/mmcblk0p8  264224   395295   131072   64M unknown
  /dev/mmcblk0p9  395296   397343     2048    1M unknown
  /dev/mmcblk0p10 397344 15269854 14872511  7.1G Linux filesystem
  • bhfletcher
    0 bhfletcher over 8 years ago
    Do you have a USB stick plugged in? What are the MODE switches set to?
    The Ultra96 would typically not boot without the SD Card. There is no on-board Flash, so I'm not sure what you are seeing.
    Bryan
