Ultra96 Hardware Design Ultra96 SD Card > 32GB ?
  • Subscribers 367 subscribers
  • Views 1481 views
pynqzen
pynqzen over 8 years ago
Does the Ultra96 board support > 32GB SD cards?
(Specifically for PetaLinux)
Thank you!
  • bhfletcher
    bhfletcher over 8 years ago +1 verified
    I have tested both 64 GB and 128 GB Delkin MLC Utility cards, so I am positive that 32 GB would also work. 32, 64, and 128 are all in stock at Newark -- https://www.newark.com/w/search?st=delkin+microSD&product…
  • mphillips53
    0 mphillips53 over 8 years ago
    I have had success with Sandisk 32gb cards.  All Samsung cards fail.
  • mphillips53
  • jafoste4
    0 jafoste4 over 8 years ago
    Hi Mphillips,
    I am confused by your statement, are you saying a sandisk 32gb card works? If so please share the Part #
    Thanks!
    Josh
  • bhfletcher
    0 bhfletcher over 8 years ago
    32, 64, and 128 are all in stock at Newark -- https://www.newark.com/w/search?st=delkin+microSD&product-range=utility-microsd-series
    If you need Industrial Temp, then take a look at Delkin's utility+ series -- https://www.newark.com/w/search?st=delkin+microsd&product-range=utilitypos-microsd-series
    If you want to read a good blog on why you should consider MLC cards vs. the less expensive TLC cards, check out this article:
    https://www.element14.com/community/groups/embedded/blog/2018/03/26/why-not-all-sd-cards-are-created-equal-storage-insights-1
    Bryan
  • pynqzen
    0 pynqzen over 8 years ago in reply to bhfletcher
    Hi and thank you for the replies!
    > 32GB cards are SDXC vs <= 32GB SDHC.  I tried to boot a PetaLinux image on a Samsung EVO select 64GB card and it would not boot, nor does the boot LED turn green.  I was able to boot the same PetaLinux image on a 16GB Sandisk Ultra and an 8GB Delkin card.
    Bryan, when you say it worked with larger cards what content was used on them?
  • bhfletcher
    0 bhfletcher over 8 years ago in reply to pynqzen
    I used the same out-of-box Linux design that we ship with the Ultra96 boards.
    I created 3 partitions: 1GB FAT32 with boot files, 7 GB EXT4 with file system, remainder as EXT4 user space. I was able to boot and access Linux. I filled the remaining partition with 100+ copies of a 410MB random number file.
    Bryan
