Ultra96 Hardware Design MiniDP cable to working
  • Subscribers 365 subscribers
  • Views 807 views
mike.walker
mike.walker over 7 years ago
I have a Ultra96 and a CableMatters Active MiniDp to HDMI cable with the default image loaded. I can access the Ultra96 via wifi at 192.168.2.1 however the monitor can not detect anything otu of the minidp -> hdmi converter. Any advice??
  • bhfletcher
    0 bhfletcher over 7 years ago
    We have also seen some monitor-specific sensitivity. Are you able to try a different monitor? We have had success on a variety of monitors that support 1920x1080. There are only a very limited number of resolutions supported. I believe 3840x2160 or 1280x720 may also work. If your monitor doesn't support one of those resolutions, that could be the problem.
    Are you able to try your cable combination with some other hardware to make sure the adapter and cable are good?
    Bryan
  • pocrnd
    0 pocrnd over 7 years ago
    You can try to reset the board after it's booting up. For me it works with this resolutions 2560 x 1080 and 1280 x 1080.
  • mike.walker
    0 mike.walker over 7 years ago
    FML...brand new HDMI cable....doesnt work.....thanks all
