Ultra96 Hardware Design How to change the countries setting of the keyboard?
  • Subscribers 366 subscribers
  • Views 652 views
kdali
kdali over 7 years ago
How can I change the country specific setting of the keyboard? When I connect the keyboard directly to the USB port J9 or via the JTAG board.
Regards
Kurt
  • narrucmot
    0 narrucmot over 7 years ago
    There appears to be a way to change the keyboard mapping/layout via the 'setxkbmap' X11 utility, but this doesn't appear to be installed in the out-of-box boot image.  I am not aware of any other method when using a keyboard connected directly to the board.  We can perhaps look to add this in future OS image releases.
    What country setting do you need?
    --Tom
  • zedhed
    0 zedhed over 7 years ago
    Hi Kurt,
    Which build are you using on your Ultra96?  Are you using the one that came on the SD card with your kit?  If so, have you looked at trying to change the settings under Enlightenment settings?
    Best Regards,
    -Kevin
  • roka
    0 roka over 7 years ago in reply to zedhed
    Hi Kevin
    I booted the Board with the "ultra96v2_oob_2018_3_190530.img" Image on the SD card.
    Regards
    Roger
