Ultra96 Hardware Design Ultra96 and Click Mezzanine unhappy with Ubuntu?
  • Answers 2 answers
  • Subscribers 366 subscribers
  • Views 1239 views
  • Ubuntu
  • petalinux
  • click
  • ultra96
  • xilinx-linux
  • microe click
  • click modules
drozwood90
drozwood90 over 7 years ago
Hi all,
When I plug the JTAG / USART for my Ultra96v1 and Click Mezzanine into my laptop, it seems to have an issue connecting to Ubuntu - even through a Virtual Machine running on my Windows Laptop.  When I use a terminal program in Windows, everything seems to work just fine.  Has anyone else experienced this?
Thanks!
--Dan
  • kevinkeryk
    kevinkeryk over 7 years ago +1 verified
    Hi Dan, I actually ran into this last week on my work laptop but I don't see it on my desktop workstation and I also don't see it when I plug directly into my laptop. I talked to one of the Avnet FAEs…
  • narrucmot
    0 narrucmot over 7 years ago
    Hi Dan,
    What sort of issue do you have using the JTAG/UART adapter with Ubuntu?  Just JTAG, just the UART, or both?  What version of the adapter are you using?  My main problem when using this adapter with my Ubuntu VM is remembering to "connect" it to the VM and to config the serial port settings correctly.
    --Tom
  • kevinkeryk
    0 kevinkeryk over 7 years ago
    Hi Dan,
    I talked to one of the Avnet FAEs about this and he suggested that it is the Thunderbolt port replication on my laptop docking station that is messing me up.  Sure enough, unplug from the docking station and plug into the port on the side of the laptop and everything is working as expected.
    Do you have a similar setup with a Thunderbolt connected docking station?
    Best Regards,
    -Kevin
    P.S. Thank you Jerold K!!!
  • drozwood90
    0 drozwood90 over 7 years ago in reply to kevinkeryk
    Kevin,
    That's pretty much what I see!  I also have a docking station with a thunderbolt like connection.  As soon as I plugged into a port directly on my laptop, everything was fine.
    Thanks for the heads up!
    --Dan
  • zedhed
    0 zedhed over 7 years ago in reply to drozwood90
    No problem Dan!
    Just wanted to give you a heads up about this other issue I ran into:
    USB Ethernet problem using micro-USB port of Ultra96-v2.
    Also related to my Thunderbolt docking station image
    -Kevin
