Ultra96 Hardware Design Power supply alternatives for Ultra96 board?
  • Subscribers 366 subscribers
  • Views 1169 views
  • ultra96
devrj
devrj over 6 years ago
I missed getting the Power Supply adapter for Ultra96-V2 board.
What are my alternative ways to power up the board?
Thank you,
Debraj
  • ctammann
    0 ctammann over 6 years ago
    To support max power you should feed the board with a supply capable of at least 8W. You can purchase a replacement adapter here - https://www.avnet.com/shop/us/products/avnet-engineering-services/90152-2208-3074457345635740760
    That adapter will make sure that you are able to power not only the ultra96-v2 but also any mezzanine adapters you use. It doesn't have to be that adapter, if you can find an alternative that matches the DC plug dimensions you should be fine. Again just make sure it can provide 8-10W minimum.
    The other option would be to solder pins into the JP1 holes so that you could connect a bench supply to power the board. There is silk screen on the board that show the + and -.
    Chris
  • devrj
    0 devrj over 6 years ago in reply to ctammann
    Thank you Chris! I will try with a replacement DC source or that JP1 holes.
