Ultra96 Hardware Design Ultra96v2 board failed, need RMA
  • Subscribers 364 subscribers
  • Views 566 views
alesea
alesea over 6 years ago
My Ultra96 failed after two days of operation,
First day worked fine,next day required frequent power ON, OFF to get working.  Now lights up LEDs, no wifi SSID, will not power OFF using power pushbutton.
Austin
  • mindaugas
    0 mindaugas over 6 years ago
    If you are using default ultra96 image from sd card try to reflash it. Also try to connect uart and look into console is it printing something? It happend few time to me when image in sd card got corrupted due to inappropriate shut down.
  • bhfletcher
    0 bhfletcher over 6 years ago in reply to mindaugas
    I second what mindaugas says. Try reflashing your SD Card. If you find you do need an RMA, I believe the standard board warranty is 45 days. You'll need to get back in contact with whichever organization from whom you purchased the board.
    Good luck!
    Bryan
