Ultra96 Hardware Design ZUBoard 1CG PCB is overheating near the power lines
  • Subscribers 364 subscribers
  • Views 570 views
  • ZUBoard 1CG PCB is overheating near the power lines
Ravi_V
Ravi_V over 1 year ago
I have observed overheating (60 degrees) on the ZUBoard 1CG PCB around the power lines area. Has your team noticed this earlier?
  • iksevas
    iksevas over 1 year ago
    There is a rail that gets warm but it is well within its operating range.
  • tjaekel
    tjaekel over 1 year ago in reply to iksevas
    Yes, my one gets hot as well, where all the power regulators are: 62C with a contactless temp. sensor.
    So, I think: even it is annoying to get a board so hot (that I could burn my fingers), it is still in the range of specs. (but what is the live time of involved regulator chips?)
    It is obvious: power chips want to see 15V from USB-C and then bring it down to 3V3, 1V8, 1V2. With 2A total current, it results in 23W to burn. Even most of the regulators are SMPS, it is a bit annoying to see the board getting so hot, especially mainly just on Power Supply (FPGA with passive heat sink is even cooler).
    I think, it is 'intended' this way, works fine for me to let the board run for days, just 'don't touch' the board.
