Ultra96 Hardware Design v2 board SD boots but no WiFi access
  • Replies 17 replies
  • Subscribers 368 subscribers
  • Views 3074 views
  • v2
fuzzynavel
fuzzynavel over 7 years ago
I’m using supplied sd card.  Image used from //avnet.me/ultra96-v2-oob link.  ultra96v2_oob_2018_3_190530.img  Followed directions from quick start card.  Minutes after boot there is no WIFi access.  No D9 LED light. Card is otherwise behaving as expected in quick start card guidance.   Thanks for any suggestions
  • jafoste4
    jafoste4 over 7 years ago in reply to jhane +2
    Hi Jeff and all, We just finished completing the 2018.3 BSP targeting Ulta96-V2. This BSP has the working WIFI support built in your requesting. To avoid any additional time lag please use this link to…
  • jafoste4
    jafoste4 over 7 years ago in reply to emso2 +1
    Hi Emile, That's your problem, you need to use your own internet SSID and Password for your local network. In case your not familiar with the terms. SSID is the name of your wifi network. psk is the password…
  • jhane
    jhane over 7 years ago in reply to emso2 +1
    Well, at least you have the "secret" codenames to build the image correctly. I didn't figure this out until I already tried setting up and building the petelinux image. As you may have already discovered…
  • bhfletcher
    bhfletcher over 7 years ago
    Sorry for the delay. I am working on that document. Also, at the time we released that May 30th image, the Access Point wasn't working yet. Therefore, you have to configure it manually to work. See the instructions below. I hope to have a new image by next week with the Access Point working.
    Before bringing up the WiFi interface you must first edit the /home/root/wpa_supplicant.conf file with the correct SSID and security password for your WiFi access point.  Once that is done you can run the supplied /home/root/wifi.sh script to copy the wpa_supplicant.conf file to /etc, load the kernel modules for the driver, and bring up the WiFi interface:
    #Copy the supplied wpa_supplicant.conf file to /etc
    #!!!NEED TO EDIT WITH SSID & PASSWORD FIRST!!!
    cp -f /home/root/wpa_supplicant.conf /etc
    # Load ATWILC3000 driver
    modprobe wilc-sdio
    # bring up interface
    ifconfig wlan0 up
    #Run wpa_supplicant for secure networking:
    wpa_supplicant -Dnl80211 -iwlan0 -c/etc/wpa_supplicant.conf -B
    #To add DHCP:
                udhcpc -i wlan0
  • bhfletcher
    bhfletcher over 7 years ago in reply to bhfletcher
    Were you successful with these instructions? I have also included these in the Getting Started Guide posted here:
    Ultra96-V2 Development Board | Zedboard
    The next version will have the Ultra96-V2 acting as an Access Point, so it will be a bit simpler.
    Bryan
  • emso
    emso over 7 years ago in reply to bhfletcher
    I'm facing the same issue. I have followed the instructions of the "Getting started" and here what I get :
    root@ultra96v2-oob-2018-3:~# ./wifi.sh
    [ 2576.363612] power up request for already powered up source Wifi
    [ 2576.369550] Device already up. request source is Wifi
    Successfully initialized wpa_supplicant
    udhcpc (v1.24.1) started
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Sending discover...
    Do you have any idea ?
    Emilie
  • jafoste4
    Hi Emillie,
    Did you enter your SSID and password into the wap_supplicant file?
    -Josh
  • emso2
    emso2 over 7 years ago in reply to jafoste4
    Hi Joshua,
    Thank you for you quick reply!
    Yes I did, at least, I entered the following:
    ctrl_interface=/var/run/wpa_supplicant
    ctrl_interface_group=0
    update_config=1
    network={
          key_mgmt=WPA-PSK
         ssid="RCK_MY_WRLD"
         psk="AABBCCDDEEFF00112233445566"
    Do I have to use my own password and SSID? If yes, where can I find it ?
    Emilie
  • jafoste4
    Hi Emile,
    psk is the password for that wifi network.
    Does that make sense?
    -Josh
  • emso2
    Ok I understand now.
    I thought it was like the Ultra 96 V1, I mean, the Ultra 96 v1 provides a wifi network. Is the Ultra 96 v2 able to do that?  or can we just connect the u96 v2 to a network ?
    Emilie
  • jafoste4
    Hi Emile,
    We are currently working on getting the wireless access point working with the Ultra96-V2. Please stay tune for the latest BSP!
    -Josh
  • emso2
    One last question !
    Does it mean that I cannot create my own Petalinux project ?  I mean, if I use settings like :
    DTG Settings → (zcu100-revc) MACHINE_NAME
    u-boot Configurations → (xilinx_zynqmp_zcu100_revC_defconfig) u-boot config target
    Yocto Settings → (ultra96-zynqmp) YOCTO_MACHINE_NAME
    Will it works ?
    Emilie
  • clem57
    clem57 over 7 years ago in reply to emso2
    Better to wait than jumping in head first unless you are ready to drink from a fire hose.image
