Ultra96 Hardware Design Ultra96 Accelerated Image Classification
  • Subscribers 366 subscribers
  • Views 924 views
wazhar
wazhar over 7 years ago
Is Ultra96-V2 board supported by this example https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841949/Zynq+UltraScale+MPSoC+Accelerated+Image+Classification+via+Binary+Neural+Network+TechTip?
I carefully followed the steps described on Xilinx Wiki but my board does not boot..
Here are the steps that I followed:
  1. Burning ultra96 image to sd card and copying boot files to root of the partition.
  2. Changed boot mode switches to boot from sd card.
  3. Connected everything monitor/keyboard/mouse ( except camera )
When power up 'D1' (done led) remains off, 'D2' led is green , 'D3' (INIT_B) led is red.
WAzhar
  • jafoste4
    jafoste4 over 7 years ago
    hi wazharm
    Are you using Etcher or win32 disk imager to burn your image?
    Please make sure your burning the 20180424_zcu102_ultra96_aicdemo.imgfile and not the zip file.
    Josh
  • jafoste4
    jafoste4 over 7 years ago in reply to jafoste4
    Also please make sure your using Ultra96-V1. This design will not work with the V2.
    -Josh
  • wazhar
    wazhar over 7 years ago in reply to jafoste4
    Hi Josh,
    I tried Etcher as well as 'dd'. Same issue.
    WAzhar
  • wazhar
    Hi Josh,
    I am using Ultra96-V2, so I guess it will never work. Any idea if V2 would be supported in future ?
    W.Azhar
  • jafoste4
    jafoste4 over 7 years ago in reply to wazhar
    Yes that is correct, the Ultra96-V2 is not compatible due to the change in memory from the v1 to v2. I am not aware of any current effort taking place to update this design. If you take on the effort please share the results!
    -Josh
