Ultrazed Hardware Design UltraZed Engineering Silicon
  • Replies 11 replies
  • Subscribers 361 subscribers
  • Views 1936 views
Can you give any timelines of when UltraZed will feature production silicon?
Best regards
Manuel Caballero
    e14 Contributor over 9 years ago +1 verified
    The production silicon will be available late March 2017. We typically need 20 working days to build boards, so if the production devices are released on schedule, we will have UltraZed-EG SOMs with production…
    0 e14 Contributor over 9 years ago
    The production silicon will be available late March 2017. We typically need 20 working days to build boards, so if the production devices are released on schedule, we will have UltraZed-EG SOMs with production devices available late April.
  • dyessgg
    0 dyessgg over 9 years ago
    Has there been any update on this?  Was production silicon released in March?  Any new projections on release of UltaZed kits?
    On related note, has anyone heard when Vivado 2017.1 will be released?
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Dyessgg,
    Xilinx will be beginning the shipment of the production silicon next week, but Avnet may or may not be their first customer to get the production parts. Upon recieving these production parts, the SOMS will be ready 20 working days after that. I will post back on this topic if I find more information out.
    As for Vivado 2017.1, from my understanding it is scheduled to be released sometime this month for public access. I do not know of a hard date, however I am under the assumption it will be near the end of the month. I will post back if I find any more information out in regards to this topic.
    --Josh
    If I got an board with ES1 now, do you know if there will be Vivado versions in the future which do not support the engineering samples anymore and will only work with production silicon?
    I remember this wasn't the case with the old Zynq 7000, but you also didn't need to get a stupid license from Xilinx to be able to build for ES at all. If I can't use my board (which I just got a week ago) with newer versions of Vivado, that would be a big let-down.
  • jafoste4
    Hi Andy,
    I highly doubt that Xilinx would make the ES1 devices obsolete with their future Vivado releases. This would alienate their existing customers. However, just to double check I am going to suggest that you make a post over at the Xilinx forum to get a validated answer to your question.
    https://www.xilinx.com/
    --Josh
  • jafoste4
    It appears Vivado 2017.1 has officially been released.
    https://www.xilinx.com/support/download.html
    --Josh
  • zjeng
    0 zjeng over 9 years ago
    Hi, are there only ES-1 and (currently?) production silicon versions delivered or ES-2 version as well?
    I try to order any of this versions from Europe/Germany but lead time is several months, even for ES-1.
    I wonder if I have to order ES-1 or production version now (e.g. if ES-1 will be still produced wven when production silicon is available)?
    What would be the fasted way to get a kit?
    Thanks, Ric.
  • jafoste4
    Hi Ric,
    Sorry for the wait.
    We are currently out of stock of the UltraZed ES1 Starter kits. At this time we do not have any plans to build any more UltraZed kits with the ES1 parts. What I mean by this is, our next build will be done using the Production Silicon. These Production Silicon UltraZed kits will be available sometime mid July.
    The fastest way you could get an UltraZed kit as of now is to order the Production Silicon kit with an estimated arrival of mid July. Sorry for the inconvenience.
    Here are the part # for you to order from
    UltraZed Production Silicon Starter Kit - AES-ZU3EG-1-SK-G
    UltraZed Production Silicon SOM - AES-ZU3EG-1-SOM-I-G
    --Josh
    Any movement on this?  Thanks.
  • dyessgg
    Quickly checking AvnetExpress.com for the UltraZED Starter Kit shows they expect delivery (to Avnet?) by 8/9/2017.  Not sure exactly what that means for ordering/receiving one though.
    I tried to paste the link but couldn't for some reason.
