Ultrazed Hardware Design UltraZed-EG ethernet not working
  • Subscribers 360 subscribers
  • Views 826 views
a.ineo
a.ineo over 8 years ago
Hello Everyone,
I having issue with the ethernet interface on my UltraZed-EG.
Ethernet interface is working great when i use "uz3eg_iocc_2017_2.bsp".
But, i'm trying to make it works on my PetaLinux 2017.2 image generated with my hdf file (Vivado 2017.2).
The system boot correctly but the ethernet interface is not detected.
I found the following error message:
dmesg | grep ethernet
[    2.768313] macb ff0e0000.ethernet eth0: Could not attach to PHY
I try to generate a new image using the official hdf (nested in "uz3eg_iocc_2017_2.bsp") but i have the same error.
Thank you,
  • rgb-sti
    0 rgb-sti over 8 years ago
    If you have created a new PetaLinux project using your hdf, have you also updated the board level device tree customisation?
    If not, you can copy this from your original bsp. It's the system-user.dtsi, probably located in project-spec/meta-user/recipes-bsp/device-tree/files. This has the eth3 bindings required.
    You may also need the other bindings from here to get some of the other components working.
  • a.ineo
    0 a.ineo over 8 years ago
    Solved using this:
    https://forums.xilinx.com/t5/Embedded-Linux/ethernet-adapter-not-found-petalinux-2017-1/td-p/772804
    Thank you.
