Ultrazed Hardware Design Detailed Dimensions
  • Subscribers 360 subscribers
  • Views 572 views
Detailed Dimensions
rnobis
rnobis over 9 years ago
I'm trying to find more detailed dimensions for the UltraZed-EG SOM and Ultrazed Carrier Card. I am able to find the dimensions of the footprint for both, 8 in x 3 in and 3.5 in x 2 in respectively, but I cannot find the depth of either. Can you please provide this information? Also, is there anyway you can provide the depth of the two together when the SOM is mounted on the carrier card?
  • jafoste4
    0 jafoste4 over 9 years ago
    We are currently looking into this.
    Thank you for your patience.
    --Josh
  • jafoste4
    The total depth of the IOCC, with the SOM is 1.700". The total depth would be 1.150" if our Heatsink solution is not used.
    Josh
  • rnobis
    0 rnobis over 9 years ago in reply to jafoste4
    Do you have the measurements of the PCB to the largest component on the bottom of the carrier card (the connector for the SOM being the top) by any chance as well?
