Ultrazed Hardware Design Ultrazed board not detected in Vivado 2017.2
  • Subscribers 360 subscribers
  • Views 818 views
metinburak_
metinburak_ over 8 years ago
I have purchased a Ultrazed board kit with red silkscreen. I have generated license with voucher and installed the board files. But the Ultrazed board is not detected in Vivado 2017.2. I am using Ubuntu 16.04. The license says XCZU3EG-ES1 bitgen is ok.
      Any suggestions?
  • jafoste4
    0 jafoste4 over 8 years ago
    When you installed VIvado did you select the option to enable engineering silicon devices? By default Engineering SIlicon is not selected during standard install.
    --Josh
  • metinburak_
    0 metinburak_ over 8 years ago
    Thanks, i can not remember but now i’m checking.
  • metinburak_
    Hi Foster,
    In first installation, they were not installed, but then, in Vivado Help, I have installed them but the problem continues. Shall i reinstall Vivado?
  • metinburak_
    Hi Foster,
  • jafoste4
    Before you reinstall, check your Xilinx license manager and make sure the ES1 license is installed correctly.
    To do so, when you open the license manager click on View License Status. Verify the version limit is set to 2017.2 or later and also verify the Host IDs Match.
    If everything there seems in order then please reinstall Vivado.
    --Josh
