Ultrazed Hardware Design Utrazed IO board hardware defintion files
  • Subscribers 360 subscribers
  • Views 769 views
e14 Contributor over 8 years ago
Hi  I am using Vivaldo 2017.2 trying to install the hardware definitions files for  UltraZed IO carrier board which we have
I downloaded  the ultrazed_board_definition_files_v2016_4.zip from Avnet site and extract it to Vivaldo folder ( I did not found the files for 2017.2 , only 2016.4 – latest version on site)
D:\Xilinx\Vivado\2017.2\data\boards\board_files
Fullscreen contentimage_90492.html Download
<html><head><title>Jive SBS</title></head>
<body><font face="arial,helvetica,sans-serif">
<b>Error</b><br><font size="-1">
An general error occurred while processing your request.
</font></font></body></html>
And still I did not see it in Vivaldo board list , when i start new project
Any idea why its does not work, may be because I version difference ? Vivaldo 2017.2 and board definitions files for 2016.4?
    0 e14 Contributor over 8 years ago
    You need to install the 2017.2 version of the files. They are posted on both, the SOM and IO Carrier Card web pages under Documentation section.
  • 100ling
    0 100ling over 8 years ago
    I can confirm that this part of the process works :-)
    Just downloaded the 2017.2 board definition files and used them for a new design in vivado 2017.2
    0 e14 Contributor over 8 years ago in reply to 100ling
    Thanks  for fast response
    But where  can i find this version of board definition files ?
    The latest version which i see  is 2016.4 in UltraZed_EG_SK_Tutorial_2016_4_v1.zip  from UltraZed-EG Starter Kit Tutorial – Vivado 2016.4  download section
    I need 2017.2 there is only 2016.4
    Its solved
    Thanks  all
    Its was hidden under "View all" button in Documentation section .
    Thanks again
