Ultrazed Hardware Design USB 3.0 bare-metal device
  • Replies 7 replies
  • Subscribers 361 subscribers
  • Views 1892 views
ashutkin
ashutkin over 9 years ago
Hello!
I'm trying to run USB 3.0 bare-metal device on my UltraZed-EG SOM mounted to UltraZed PCIe Carrier Card.
First of all I created a hdf using UltraZed PCIe Carrier Card Tutorial – Vivado 2016.4 (form here).
Next I re-configured Zynq UltraScale+ MPSoC IP and enabled USB3.0 on PS-GTR lane 0 for the USB0 controller.
And for this design I launched Xilinx usbpsu example v 1.1 from 2016.4 SDK drivers library (this one).
Mass storage device works, but only on HighSpeed (usb 2.0), not SuperSpeed.
Is there any example, instruction or reference design for working USB3.0 device?
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello ashutkin,
    As of now the only 3.0 reference design material we have it is the Open Source Linux USB3 Performance Test Turorial we offer located here http://zedboard.org/support/design/17596/131
    --Josh
  • ashutkin
    0 ashutkin over 9 years ago in reply to jafoste4
    Yes, I already checked it, this tutorial is for Linux USB host, but I work with bare-metal USB device.
    I found in appendix in this tutorial some recommendation about dynamic clock adjustments. Is this problem also affect PCIe Carrier Card like IO Carrier Card?
  • zedhed
    0 zedhed over 9 years ago
    Hi ashutkin,
    The PCIe Carrier Card has the same clock generator as the IO Carrier Card so it is possible it was built with a part which had the incorrect configuration loaded to it also.
    You should be able to access the I2C interface on the clock device in a similar manner from your bare metal application using the Xilinx Standalone I2C APIs and reusing the clock configuration found in the appendix of the document that Josh highlighted.
    Best Regards,
    -Kevin
  • ashutkin
    0 ashutkin over 9 years ago in reply to zedhed
    I'm trying to reproduce Open Source Linux USB3 Performance Test Tutorial on PCIe Carrier Card
    This tutorial provides BOOT.BIN and image.ub files, but they are for UltraZed IO Carrier Card and will not work (I suppose) with my UltraZed PCIe Carrier Card.
    I can get BOOT.BIN and image.ub from PCIe Carrier Out-of-box design, is it possible to run USB3 test with these images, or I must compile specific image for USB3 test? If so, how can I compile it?
  • zedhed
    Hi ashutkin,
    I think the only piece of the puzzle that is missing from the PCIe Carrier OOB design is the full blown dd that is used for the performance testing.
    Once you apply the same I2C commands to set the IDT Clock Configuration and do a warm reboot, then USB 3.0 should work at 5.0Gbps rates.
    One other important piece is the USB 3.0 adapter as I had some difficulties in establishing a reliable 5.0Gbps link with some other cables.
    Connector:
    https://www.firefold.com/usb-3-0-type-a-female-to-micro-usb-type-b-male-adapter
    Best Regards,
    -Kevin
  • ashutkin
    Hello!
    I already tried to apply this tutorial to PCIeCarrier OOB few days ago with no success.
    I launched appropriate i2cset commands, checked registers with i2cdump -y 2 0x6a, did a warm reboot, but lsusb -t still shows me, that my mass storage device operates 480M, not 5000M.
    I don't know where to buy firefold products in my country, but I has this adapter: https://ugreen.com/product/UGREEN_Micro_USB_3_0_male_to_USB3_0_Female_OTG_On_The_Go_Cable-en.html
    How do you think can it be a reason of my problem?
  • ashutkin
    I have applied I2C programming instructions in my bare-metal architecture and it solved problem for me, the USB 3.0 controller works now.
