Ultrazed Hardware Design UltraZed EV PCIe Issue
  • Subscribers 358 subscribers
  • Views 326 views
jafoste4
jafoste4 over 8 years ago
Hello All,
If you have recieved one of the first 18 shipped UltraZed EV Starter Kits the PCIe Clocks on the Carrier Card were not programmed. This only affects those whom need the PCIe interface for their desired application.
To program the PCIe interface is simple. Travel to the following link which takes you to the documentation page for the UltraZed EV http://zedboard.org/support/documentation/22581 and download the file labeled UltraZed EV Carrier Card FAT.
This will provide you with a file labeled Avnet_UltraZed-7EV_Carrier_2017_3_FAT_Release_RC1.zip. Unzip the contents (Boot.bin, image.ub) to an SD Card, set the UltraZedEV Starter kit to SD card boot. Plug in the SD Card to the Started Kit and power on to boot from SD Card.
At the end of the test your PCIe clocks will be programmed correctly.
Note: Do no worry if you see failure in the terminal window for any of the Carrier Cards interfaces. This is due to not having the correct Hardware plugged in to pass the tests.
Feel free to PM me with questions.
--Josh
