Ultrazed Hardware Design ES1 Silicon License
  • Replies 17 replies
  • Subscribers 365 subscribers
  • Views 2214 views
ES1 Silicon License
derek_greene@logicircuit.com
derek_greene@logicircuit.com over 9 years ago
I am pretty positive I have ES1 silicon (JTAG ID 04710093). However, there was no voucher in the shipment to get an ES1 license for Vivado. I have multiple seats of Vivado, but 2016.4 will not target this device without a license for ES1. I have contacted Avnet customer support about the missing voucher, but they closed my case saying that this product does not come with a voucher. How is that possible? How am I supposed to build anything and target this board if I am unable to get an ES1 license? I am not aware of a way to get a license without a voucher.
Derek
  • jafoste4
    jafoste4 over 9 years ago +1 verified
    Hi Derek, Sorry about the inconvenience. Please refer to your private messages (Top right hand corner of webpage) and I will help rectify your issue. --Josh
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Derek,
    --Josh
  • derek_greene@logicircuit.com
    0 derek_greene@logicircuit.com over 9 years ago in reply to jafoste4
    Thanks for the help! This solved my problem. On to the next one!
  • liyumove
    0 liyumove over 9 years ago
    @JFoster, met the same problem, any solution?
  • mtsao
    0 mtsao over 9 years ago
    I may have a related issues.
    my Linux 2016.4 is showing only "-EVAL" parts, but UltraZed voucher .lic was generaedted for "-ES1" parts.
    http://zedboard.org/content/ultrazed-board-file-20164-not-getting-detected-vivado
  • jafoste4
    0 jafoste4 over 9 years ago in reply to liyumove
    Hi liyumove,
    Please refer to your private messages in the top right hand corner of the webpage and ill get your sorted out.
    --Josh
  • jafoste4
    Hi mtsao,
    I am currently looking into your issue, I will respond back when I find out the proper course of action.
    --Josh
  • rsk_hayashi
    0 rsk_hayashi over 9 years ago
    I have been facing the same problem (no voucher).
    Could you please give me a solution?
    Ryosuke
  • jafoste4
    Hello Ryosuke,
    Did you recieve an ES1 device(red) or production device (black)? Also did you purchase just the SOM or the whole starter kit?
    Josh
  • rsk_hayashi
    0 rsk_hayashi over 9 years ago in reply to jafoste4
    http://zedboard.org/content/ultrazed-eg-board-files-not-found-vivado
    Hi Josh,
    I'm sorry, I misunderstood.
    I received a production device.
    But I have another issue. UltraZed-EG Board File is not detected in Vivado.
    I thought that the problem will be solved by what the above thread says.
    I dont know what causes it.
    Ryosuke
  • jafoste4
    Hello Ryosuke,
    What version of Vivado are you using? If you could please download Vivado 2017.2 if not done so and retry again that would be appreciated.
    The reason I ask this is that in Vivado 2016.4 or older it appears that the Zynq UltraScale+ device is only in an eval stage not production. That would prevent the BDF from loading correctly.
    Josh
    --Josh
