Ultrazed Hardware Design Ultrazed Board File 2016.4 not getting detected in Vivado
  • Replies 37 replies
  • Subscribers 362 subscribers
  • Views 4427 views
I have extracted the three folders of ultrazed_board_definition_files_v2016_4.zip to <Installation Directory>/Vivado/2016.4/data/boards/boards_files/ .
The names of three folders are
1) ultrazed_3eg_iocc_es1
2) ultrazed_3eg_som_es1
3) ultrazed_3eg_pciecc_es1
Still Vivado 2016.4 do not see board files while creating the project.
I am following UltraZed_EG_Starter_Kit_Tutorial_Vivado_2016_4.pdf to kickstart the project.
Is this any known issue and is there any work around for this ? Or Am I missing any steps?
Goutham
    0 e14 Contributor over 9 years ago
    Please follow the instructions listed on the UltraZed-EG Starter Kit Quick Start Card (QSC) shipped with the Starter Kit to install the ES1 license and enable the ES1 devices. You can also download the QSC from our website microzed.org/support/documentation/14201.
  • mtsao
    0 mtsao over 9 years ago
    Followed the direction, but the 3 UltraZed board files didn't show up.  Any clues?
    I am running on CentOS 7.x
    569 Beta devices matching pattern found, 0 enabled.   [!!! 0 enabled !!!]
    [owluser@IBM-X3650M4 UltraZed]$ vivado
    ****** Vivado v2016.4 (64-bit)
      **** SW Build 1756540 on Mon Jan 23 19:11:19 MST 2017
      **** IP Build 1755317 on Mon Jan 23 20:30:07 MST 2017
        ** Copyright 1986-2016 Xilinx, Inc. All Rights Reserved.
    Sourcing tcl script '/opt/Xilinx/Vivado/2016.4/scripts/init.tcl'
    start_gui
      cat init.tcl
      enable_beta_device*
      uname -a
      Linux  3.10.0-514.10.2.el7.x86_64 #1 SMP Fri Mar 3 00:04:05 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
    ll /opt/Xilinx/Vivado/2016.4/data/boards/board_files
    total 0
    drwxr-xr-x. 4 root root 26 Apr  6 10:44 ac701
    drwxr-xr-x. 5 root root 36 Apr  6 10:41 kc705
    drwxr-xr-x. 4 root root 26 Apr  6 10:42 kcu105
    drwxr-xr-x. 3 1001 1001 16 Mar 28 15:21 ultrazed_3eg_iocc_es1
    drwxr-xr-x. 3 1001 1001 16 Mar 28 15:21 ultrazed_3eg_pciecc_es1
    drwxr-xr-x. 3 1001 1001 16 Mar 28 15:21 ultrazed_3eg_som_es1
    drwxr-xr-x. 4 root root 26 Apr  6 10:42 vc707
    drwxr-xr-x. 5 root root 36 Apr  6 10:42 vc709
    drwxr-xr-x. 4 root root 26 Apr  6 10:42 vcu108
    drwxr-xr-x. 3 root root 16 Apr  6 10:42 vcu110
    drwxr-xr-x. 3 root root 16 Apr  6 10:42 vcu118
    drwxr-xr-x. 3 root root 16 Apr  6 10:42 zc702
    drwxr-xr-x. 4 root root 26 Apr  6 10:41 zc706
    drwxr-xr-x. 3 root root 16 Apr  6 10:41 zcu102
    drwxr-xr-x. 3 root root 16 Apr  6 10:42 zed
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Mtsao,
    Did you install the ES1 license and enable the ES1 devices? Can you see any of the EG ES1 devices when you go to create a new project?
    --Josh
  • mtsao
    Here is a clue:   No -ES1 shown in " Dafault Part  ->   Family  ->  Zynq UltraScale+  -> parts"
    Are the "-ES1" parts remoived from this Vivado 2016.4 build?
    On the License Manager  Status panel, showing 2 rows:
    XCZU3EG-ES1_bitgen
    xczu3eg-es1
    On the New Project  ->  Default Part -> Family : Showing two pull-downs
    Zynq UnltraScale+     ->  xczu3eg-xxxxxxx-EVAL          [[[!!!   NO -ES1 here,  only -EVAL parts  !!!]]]
    Zynq UltraScale+ ES2   ->  xczu9eg-xxxxxx-es2
  • mtsao
    Here is something:
    Went into the board files dirs, changed all occurrences of ES1 to EVAL,  -es1 to -EVAL.
    Now the board packages showed up.   HOWEVER !!!
    HOWEVER !!!  probably can not gen bit file, since the LICENSE entry are for -es1 [!!!] parts, not for -EVAL parts.
    In the meantime, while waiting for a definitive solution, I am pushing ahead ....
  • jafoste4
    Hi mtsao,
    I believe you installed the "Zynq UltraScale+ MPSoC Early Access License 2016.4 Devices" located on Xilinx's website correct? If that is the case then the devices you are seeing are correct.
    The correct license you needed to install for the ES1 Silicon devices should have came with your development kit(Sheet of papter with license information). If for some reason you did not recieve this license with your development kit, please reach out and I will assist in providing you one.
    Josh
  • mtsao
    Not sure the implication of "Zynq UltraScale+ MPSoC Early Access License 2016.4 Devices"
    I followed the instructions on the kit & on the Xilinx License site, typed in the voucher #'s.  Received a xilinx.lic file, with these entries.  Note the "xczu3eg-es1"
    The "-ES1" is consistent between the .lic & the board files.  But my Linux 2016.4 Vivado does not have -es1 parts.  It only has -EVAL parts.
    Could this be a wrong build (newer/older) of Vivado 2016.4?  or a Win vs. Linux issue?  (at this point I don't have a Win machine available to cross check.  & I had already used up this one voucher.)
    Will let you know how far I got with board files's <part_info part_name="xczu3eg-sfva625-1-i-EVAL">
    when working through "UltraZed-EG Starter Kit Tutorial (Vivado 2016.4) Version 1.0 10 December 2016"
    # This is a permanent license generated on Sun Apr 09 17:24:43 UTC 2017
    INCREMENT Synthesis xilinxd 2018.04 permanent uncounted 7AA2FDA8FDE9 \
    VENDOR_STRING=mtsao,Synthesis,software,permanent,_177802448_176019825_210655882_161 \
    HOSTID=40f2e99b4b85 ISSUER="Xilinx Inc" START=09-Apr-2017 \
    TS_OK
    INCREMENT xczu3eg-es1 xilinxd 2018.04 permanent uncounted \
    2BBB08F4E039 \
    VENDOR_STRING=mtsao,xczu3eg-es1,software,permanent,_177802448_176019825_210655882_723 \
    TS_OK
    INCREMENT XCZU3EG-ES1_bitgen xilinxd 2018.04 permanent uncounted \
    BAC18A1E8B89 \
    VENDOR_STRING=mtsao,XCZU3EG-ES1_bitgen,software,permanent,_177802448_176019825_210655882_626 \
    TS_OK
  • mtsao
    Is this "Zynq UltraScale+ MPSoC Early Access License 2016.4 Devices" a special file?
    Googling turned up this entry:
    https://forums.xilinx.com/t5/Installation-and-Licensing/Re-ZCU102-ES2-License-Issue/td-p/751111
    But I don't have access to "UltraScale+ FPGA Errata lounge"
  • mtsao
    Deeper into the rabbit hole.    Singed up, 48 hours wait.
    https://www.xilinx.com/support/answers/62603.html
    AR# 62603 Virtex UltraScale FPGA VCU108 Evaluation Kit - Known Issues and Release Notes Master Answer Record
    https://www.xilinx.com/support/answers/65127.html
    AR# 65127 UltraScale Architecture Early Access Errata Lounge Link
  • mtsao
    Well, no license for -EVAL parts.   The UltraZed voucher genernated .lic for -ES1 parts.
    Maybe time to begin a new thread of discussion.
    ERROR: [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xczu3eg-EVAL'.
    Please run the Vivado License Manager for assistance in determining
    which features and devices are licensed for your system.
    Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ".
    This is my configuration:
    XCZU3EG-ES1_bitgen
    xczu3eg-es1
