Ultrazed Hardware Design IR PowIRCenter config. file
  • Replies 7 replies
  • Subscribers 361 subscribers
  • Views 2137 views
e14 Contributor over 8 years ago
We would like to use the same power ic - Infineon IRPS5401MTRPBF PMIC on our own carrier board for the UltraZed-EG SOM. Could you please provide the PowIRCenter configuration file to us? Thank you very much!
Best,
Pei
  • ctammann
    0 ctammann over 8 years ago
    Hi Pei,
    If you plan to use the same configuration I have a file I can provide. You will need to make sure the schematic matches that of the carrier documentation on this site. Please PM me with your email address and I can provide it directly.
    Chris
  • ckaven
    0 ckaven over 8 years ago
    Chris,
    Sorry to bring up an old thread but I also need the config file for the IRPS5401 setup that is on the UltraZed carrier card. We have designed a custom carrier card that uses the PMIC exactly like the Avnet setup.  Any help you could provide would be greatly appreciated.
    Kyle
  • ctammann
    0 ctammann over 7 years ago
    Hey Kyle, sorry for the delay. Please PM me with your email and I'll send you the files.
  • rogerallen0302
    0 rogerallen0302 over 7 years ago in reply to ctammann
    Hi Chris,
    Can you give me the config file also?
  • ctammann
    0 ctammann over 7 years ago in reply to rogerallen0302
    Hey Roger,
    We now have a website set up to request the files here - http://avnet.me/AvnetProgrammingFiles
    Please try submitting the request there so I can make sure the system is working properly. I will get the request and be able to supply the files. If it doesn't work for some reason let me know and I'll be sure to get them to you.
    Chris
  • rogerallen0302
    Hi Chris,
    I filled in the request and submitted,pls check.
    The Kit/Board only can choose Ultra96-V2,but my need is UltraZed-EG IO carrier card.
    I have designed a custom carrier card that uses the PMIC exactly like the Avnet setup,I will try to bring my board up after you mail me the config file.
    Thanks.
  • ctammann
    Thanks Roger,
    I got your request through the web portal and replied.
