Ultrazed Hardware Design Partial Reconfiguragtion support in Ultrazed
  • Subscribers 358 subscribers
  • Views 410 views
I have the partial reconfiguration license for the vivado version I am using. But when I try to do it in Ultrazed , specifically when I try to set that property ON using set_propoerty HD.RECONFIGURABLE true [ get_cells <cell_name>] command, I get this error :
ERROR: [Common 17-69] Command failed: HD.RECONFIGURABLE can only be applied for target parts that support Partial Reconfiguration.
I cannot do partial reconfiguration in Ultrazed? Do I need to select different hardware in Vivado that , matches Ultrazed?
Is this related to the discussion in this link? Same reason?
https://forums.xilinx.com/t5/UltraScale-Architecture/Partial-Reconfiguration-for-Zynq-UltraScale-MPSoC/td-p/746586
  • drozwood90
    0 drozwood90 over 9 years ago
    Hi there,
    I think you found the answer!  The UZ boards are currently built with ES1 silicon.  As Xilinx is saying it is disabled for now, I would say that is true.
    If you really HAVE to have this immediately, I would suggest you contact your local FAE and see if they can work with Xilinx to provide you an exception.  As this is ES1 silicon, I would not expect that for now - however it does not hurt to ask if you can be placed on a pilot program!
    --Dan
