Ultrazed Hardware Design Ethernet is not working on UltraZed Board
  • Subscribers 359 subscribers
  • Views 1551 views
tarekeldeeb
tarekeldeeb over 8 years ago
I tried UltraZed Board with the off-the-shelf SD Card and it's booting correctly.
But I have a problem with the Ethernet, I cannot find eth0
  I attached the linux booting log file.
  I have in trace:
   [    3.423519] macb ff0e0000.ethernet eth0: Could not attach to PHY
  Do you have an idea how to solve this problem?
  <!--break-->
  ---------- Log -------------
   Avnet modifying SDHCI0 and SDHCI1 registers for UltraZed SOM
   Xilinx Zynq MP First Stage Boot Loader
   Release 2016.2   Dec  2 2016  -  00:38:48
   Platform: Silicon, Cluster ID 0x80000000
   Running on A53-0 (64-bit) Processor
   Processor Initialization Done
   ================= In Stage 2 ============
   SD1 Boot Mode
   SD: rc= 0
   File name is 1:/BOOT.BIN
   Multiboot Reg : 0x0
   Image Header Table Offset 0x8C0
   *****Image Header Table Details********
   Boot Gen Ver: 0x1020000
   No of Partitions: 0x4
   Partition Header Address: 0x280
   Partition Present Device: 0x0
   Initialization Success
   ======= In Stage 3, Partition No:1 =======
   UnEncrypted data Length: 0x153E27
   Data word offset: 0x153E27
   Total Data word length: 0x153E27
   Destination Load Address: 0xFFFFFFFF
   Execution Address: 0x0
   Data word offset: 0x72F0
   Partition Attributes: 0x20
   Destination Device is PL, changing LoadAddress
   Bitstream download to start now
   DMA transfer done
   PL Configuration done successfully
   Partition 1 Load Success
   ======= In Stage 3, Partition No:2 =======
   UnEncrypted data Length: 0x1810
   Data word offset: 0x1810
   Total Data word length: 0x1810
   Destination Load Address: 0xFFFE5000
   Execution Address: 0xFFFE5000
   Data word offset: 0x15B120
   Partition Attributes: 0x100
   Partition 2 Load Success
   ======= In Stage 3, Partition No:3 =======
   UnEncrypted data Length: 0x17CE4
   Data word offset: 0x17CE4
   Total Data word length: 0x17CE4
   Destination Load Address: 0x8000000
   Execution Address: 0x8000000
   Data word offset: 0x15C930
   Partition 3 Load Success
   All Partitions Loaded
   ================= In Stage 4 ============
   Running +II=I▒   Incorrect XILINX IDCODE 0x14710093, maskid 0x4600093
   NOTICE:  ATF running on XCZUUNKN/silicon v4/RTL5.1 at 0xfffe5000
   NOTICE:  BL31: Secure code at 0x60000000
   NOTICE:  BL31: Non secure code at 0x8000000
   NOTICE:  BL31: v1.2(release):f9b7cd8
   NOTICE:  BL31: Built : 00:38:53, Dec  2 2016
   U-Boot 2016.01 (Dec 02 2016 - 00:40:10 -0700)
   DRAM:  2 GiB
   Enabling Caches...
   EL Level:       EL2
   MMC:   sdhci@ff160000: 0, sdhci@ff170000: 1
   Invalid bus 0 (err=-19)
   *** Warning - spi_flash_probe() failed, using default environment
   ## Error: flags type check failure for "serverip" <= "AUTO" (type: i)
   himport_r: can't insert "serverip=AUTO" into hash table
   In:    serial
   Out:   serial
   Err:   serial
   Bootmode: SD_MODE1
   Net:   ZYNQ GEM: ff0e0000, phyaddr 5, interface rgmii-id
   eth0: ethernet@ff0e0000
   U-BOOT for uz3eg-2016-2
   Hit any key to stop autoboot:  0
   Device: sdhci@ff160000
   Manufacturer ID: 13
   OEM: 14e
   Tran Speed: 52000000
   Rd Block Len: 512
   MMC version 5.0
   High Capacity: Yes
   Capacity: 7.1 GiB
   Bus Width: 8-bit
   Erase Group Size: 512 KiB
   HC WP Group Size: 8 MiB
   User Capacity: 7.1 GiB WRREL
   Boot Capacity: 16 MiB ENH
   RPMB Capacity: 4 MiB ENH
   reading image.ub
   21897092 bytes read in 1420 ms (14.7 MiB/s)
   ## Loading kernel from FIT Image at 10000000 ...
      Using 'conf@1' configuration
      Trying 'kernel@1' kernel subimage
        Description:  PetaLinux Kernel
        Type:         Kernel Image
        Compression:  gzip compressed
        Data Start:   0x100000f4
        Data Size:    21868258 Bytes = 20.9 MiB
        Architecture: AArch64
        OS:           Linux
        Load Address: 0x00080000
        Entry Point:  0x00080000
        Hash algo:    crc32
        Hash value:   515e2759
      Verifying Hash Integrity ... crc32+ OK
   ## Loading fdt from FIT Image at 10000000 ...
      Trying 'fdt@1' fdt subimage
        Description:  Flattened Device Tree blob
        Type:         Flat Device Tree
        Compression:  uncompressed
        Data Start:   0x114db0c0
        Data Size:    27524 Bytes = 26.9 KiB
        Hash algo:    crc32
        Hash value:   15a0a06b
      Booting using the fdt blob at 0x114db0c0
      Uncompressing Kernel Image ... OK
      Loading Device Tree to 0000000007ff6000, end 0000000007fffb83 ... OK
   Starting kernel ...
   [    0.000000] Booting Linux on physical CPU 0x0
   [    0.000000] Linux version 4.4.0 (training@localhost.localdomain) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09) ) #2 SMP Fri Dec 2 00:42:01 MST 2016
   [    0.000000] Boot CPU: AArch64 Processor [410fd034]
   [    0.000000] earlycon: Early serial console at MMIO 0xff000000 (options '115200n8')
   [    0.000000] bootconsole [uart0] enabled
   [    0.000000] cma: Reserved 128 MiB at 0x0000000078000000
   [    0.000000] psci: probing for conduit method from DT.
   [    0.000000] psci: PSCIv1.0 detected in firmware.
   [    0.000000] psci: Using standard PSCI v0.2 function IDs
   [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
   [    0.000000] PERCPU: Embedded 16 pages/cpu @ffffffc077f8e000 s24704 r8192 d32640 u65536
   [    0.000000] Detected VIPT I-cache on CPU0
   [    0.000000] CPU features: enabling workaround for ARM erratum 845719
   [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 517120
   [    0.000000] Kernel command line: earlycon=cdns,mmio,0xFF000000,115200n8
   [    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
   [    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
   [    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
   [    0.000000] software IO TLB [mem 0x71e00000-0x75e00000] (64MB) mapped at [ffffffc071e00000-ffffffc075dfffff]
   [    0.000000] Memory: 1840360K/2097152K available (7198K kernel code, 520K rwdata, 2736K rodata, 16596K init, 356K bss, 125720K reserved, 131072K cma-reserved)
   [    0.000000] Virtual kernel memory layout:
   [    0.000000]     vmalloc : 0xffffff8000000000 - 0xffffffbdffff0000   (   247 GB)
   [    0.000000]     vmemmap : 0xffffffbe00000000 - 0xffffffbfc0000000   (     7 GB maximum)
   [    0.000000]               0xffffffbe00000000 - 0xffffffbe01c00000   (    28 MB actual)
   [    0.000000]     fixed   : 0xffffffbffa7fd000 - 0xffffffbffac00000   (  4108 KB)
   [    0.000000]     PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000   (    16 MB)
   [    0.000000]     modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
   [    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc080000000   (  2048 MB)
   [    0.000000]       .init : 0xffffffc000a35000 - 0xffffffc001a6a000   ( 16596 KB)
   [    0.000000]       .text : 0xffffffc000080000 - 0xffffffc000a34044   (  9937 KB)
   [    0.000000]       .data : 0xffffffc001a7c000 - 0xffffffc001afe160   (   521 KB)
   [    0.000000] Hierarchical RCU implementation.
   [    0.000000]  Build-time adjustment of leaf fanout to 64.
   [    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
   [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
   [    0.000000] NR_IRQS:64 nr_irqs:64 0
   [    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
   [    0.000000] GIC: Using split EOI/Deactivate mode
   [    0.000000] Architected cp15 timer(s) running at 100.00MHz (phys).
   [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171024e7e0, max_idle_ns: 440795205315 ns
   [    0.000004] sched_clock: 56 bits at 100MHz, resolution 10ns, wraps every 4398046511100ns
   [    0.008361] Console: colour dummy device 80x25
   [    0.012619] console [tty0] enabled
   [    0.015984] bootconsole [uart0] disabled
   [    0.019892] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=400000)
   [    0.019907] pid_max: default: 32768 minimum: 301
   [    0.020041] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
   [    0.020052] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
   [    0.020755] ASID allocator initialised with 65536 entries
   [    0.021614] Detected VIPT I-cache on CPU1
   [    0.021639] CPU1: Booted secondary processor [410fd034]
   [    0.021861] Detected VIPT I-cache on CPU2
   [    0.021877] CPU2: Booted secondary processor [410fd034]
   [    0.022087] Detected VIPT I-cache on CPU3
   [    0.022103] CPU3: Booted secondary processor [410fd034]
   [    0.022132] Brought up 4 CPUs
   [    0.022168] SMP: Total of 4 processors activated.
   [    0.022178] CPU: All CPU(s) started at EL2
   [    0.022196] alternatives: patching kernel code
   [    0.022486] devtmpfs: initialized
   [    0.026191] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
   [    0.029160] xor: measuring software checksum speed
   [    0.067983]    8regs     :  2178.000 MB/sec
   [    0.108012]    8regs_prefetch:  1990.000 MB/sec
   [    0.148041]    32regs    :  2413.000 MB/sec
   [    0.188071]    32regs_prefetch:  2254.000 MB/sec
   [    0.188085] xor: using function: 32regs (2413.000 MB/sec)
   [    0.188598] NET: Registered protocol family 16
   [    0.200094] cpuidle: using governor ladder
   [    0.212101] cpuidle: using governor menu
   [    0.212146] vdso: 2 pages (1 code @ ffffffc001a81000, 1 data @ ffffffc001a80000)
   [    0.212184] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   [    0.212801] DMA: preallocated 256 KiB pool for atomic allocations
   [    0.213713] ARM CCI_400_r1 PMU driver probed
   [    0.300317] raid6: int64x1  gen()   393 MB/s
   [    0.368320] raid6: int64x1  xor()   355 MB/s
   [    0.436475] raid6: int64x2  gen()   607 MB/s
   [    0.504467] raid6: int64x2  xor()   496 MB/s
   [    0.572533] raid6: int64x4  gen()   903 MB/s
   [    0.640610] raid6: int64x4  xor()   652 MB/s
   [    0.708717] raid6: int64x8  gen()   935 MB/s
   [    0.776746] raid6: int64x8  xor()   661 MB/s
   [    0.844812] raid6: neonx1   gen()   653 MB/s
   [    0.912869] raid6: neonx1   xor()   600 MB/s
   [    0.980986] raid6: neonx2   gen()  1031 MB/s
   [    1.049022] raid6: neonx2   xor()   891 MB/s
   [    1.117089] raid6: neonx4   gen()  1395 MB/s
   [    1.185149] raid6: neonx4   xor()  1074 MB/s
   [    1.253233] raid6: neonx8   gen()  1418 MB/s
   [    1.321291] raid6: neonx8   xor()  1088 MB/s
   [    1.321304] raid6: using algorithm neonx8 gen() 1418 MB/s
   [    1.321317] raid6: .... xor() 1088 MB/s, rmw enabled
   [    1.321329] raid6: using intx1 recovery algorithm
   [    1.321562] ACPI: Interpreter disabled.
   [    1.322036] arm-smmu fd800000.smmu: probing hardware configuration...
   [    1.322053] arm-smmu fd800000.smmu: SMMUv2 with:
   [    1.322067] arm-smmu fd800000.smmu:  stage 1 translation
   [    1.322082] arm-smmu fd800000.smmu:  stage 2 translation
   [    1.322095] arm-smmu fd800000.smmu:  nested translation
   [    1.322114] arm-smmu fd800000.smmu:  stream matching with 48 register groups, mask 0x7fff
   [    1.322136] arm-smmu fd800000.smmu:  16 context banks (0 stage-2 only)
   [    1.322153] arm-smmu fd800000.smmu:  Supported page sizes: 0x60211000
   [    1.322169] arm-smmu fd800000.smmu:  Stage-1: 48-bit VA -> 48-bit IPA
   [    1.322184] arm-smmu fd800000.smmu:  Stage-2: 48-bit IPA -> 48-bit PA
   [    1.323024] arm-smmu fd800000.smmu: registered 26 master devices
   [    1.323273] iommu: Adding device fd500000.dma to group 0
   [    1.323303] iommu: Adding device fd510000.dma to group 1
   [    1.323331] iommu: Adding device fd520000.dma to group 2
   [    1.323359] iommu: Adding device fd530000.dma to group 3
   [    1.323386] iommu: Adding device fd540000.dma to group 4
   [    1.323417] iommu: Adding device fd550000.dma to group 5
   [    1.323445] iommu: Adding device fd560000.dma to group 6
   [    1.323473] iommu: Adding device fd570000.dma to group 7
   [    1.323512] iommu: Adding device ffa80000.dma to group 8
   [    1.323540] iommu: Adding device ffa90000.dma to group 9
   [    1.323569] iommu: Adding device ffaa0000.dma to group 10
   [    1.323597] iommu: Adding device ffab0000.dma to group 11
   [    1.323625] iommu: Adding device ffac0000.dma to group 12
   [    1.323656] iommu: Adding device ffad0000.dma to group 13
   [    1.323685] iommu: Adding device ffae0000.dma to group 14
   [    1.323713] iommu: Adding device ffaf0000.dma to group 15
   [    1.323752] iommu: Adding device ff0e0000.ethernet to group 16
   [    1.323812] iommu: Adding device ff0f0000.spi to group 17
   [    1.323871] iommu: Adding device ff160000.sdhci to group 18
   [    1.323900] iommu: Adding device ff170000.sdhci to group 19
   [    1.323966] iommu: Adding device amba:usb@fe200000 to group 20
   [    1.324319] SCSI subsystem initialized
   [    1.324547] usbcore: registered new interface driver usbfs
   [    1.324595] usbcore: registered new interface driver hub
   [    1.324642] usbcore: registered new device driver usb
   [    1.324749] media: Linux media interface: v0.10
   [    1.324795] Linux video capture interface: v2.00
   [    1.324838] pps_core: LinuxPPS API ver. 1 registered
   [    1.324851] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   [    1.324890] PTP clock support registered
   [    1.324939] EDAC MC: Ver: 3.0.0
   [    1.325214] Advanced Linux Sound Architecture Driver Initialized.
   [    1.325683] clocksource: Switched to clocksource arch_sys_counter
   [    1.325967] pnp: PnP ACPI: disabled
   [    1.331416] NET: Registered protocol family 2
   [    1.331840] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
   [    1.332003] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
   [    1.332291] TCP: Hash tables configured (established 16384 bind 16384)
   [    1.332363] UDP hash table entries: 1024 (order: 3, 32768 bytes)
   [    1.332420] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
   [    1.332588] NET: Registered protocol family 1
   [    1.332836] RPC: Registered named UNIX socket transport module.
   [    1.332851] RPC: Registered udp transport module.
   [    1.332863] RPC: Registered tcp transport module.
   [    1.332875] RPC: Registered tcp NFSv4.1 backchannel transport module.
   [    2.058861] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
   [    2.059589] futex hash table entries: 1024 (order: 5, 131072 bytes)
   [    2.059695] audit: initializing netlink subsys (disabled)
   [    2.059743] audit: type=2000 audit(2.048:1): initialized
   [    2.060227] HugeTLB registered 2 MB page size, pre-allocated 0 pages
   [    2.060601] VFS: Disk quotas dquot_6.6.0
   [    2.060650] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   [    2.061192] NFS: Registering the id_resolver key type
   [    2.061230] Key type id_resolver registered
   [    2.061243] Key type id_legacy registered
   [    2.061266] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
   [    2.061315] jffs2: version 2.2. (NAND) (SUMMARY)  Copyright 2001-2006 Red Hat, Inc.
   [    2.062331] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
   [    2.062358] io scheduler noop registered
   [    2.062373] io scheduler deadline registered
   [    2.062403] io scheduler cfq registered (default)
   [    2.063300] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
   [    2.063547] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
   [    2.063676] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
   [    2.063805] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
   [    2.063932] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
   [    2.064061] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
   [    2.064194] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
   [    2.064331] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
   [    2.064460] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
   [    2.064532] xilinx-zynqmp-dma ffa80000.dma: main clock not found.
   [    2.064548] xilinx-zynqmp-dma ffa80000.dma: Probing channel failed
   [    2.064582] xilinx-zynqmp-dma: probe of ffa80000.dma failed with error -2
   [    2.064647] xilinx-zynqmp-dma ffa90000.dma: main clock not found.
   [    2.064662] xilinx-zynqmp-dma ffa90000.dma: Probing channel failed
   [    2.064684] xilinx-zynqmp-dma: probe of ffa90000.dma failed with error -2
   [    2.064751] xilinx-zynqmp-dma ffaa0000.dma: main clock not found.
   [    2.064766] xilinx-zynqmp-dma ffaa0000.dma: Probing channel failed
   [    2.064788] xilinx-zynqmp-dma: probe of ffaa0000.dma failed with error -2
   [    2.064852] xilinx-zynqmp-dma ffab0000.dma: main clock not found.
   [    2.064867] xilinx-zynqmp-dma ffab0000.dma: Probing channel failed
   [    2.064889] xilinx-zynqmp-dma: probe of ffab0000.dma failed with error -2
   [    2.064953] xilinx-zynqmp-dma ffac0000.dma: main clock not found.
   [    2.064969] xilinx-zynqmp-dma ffac0000.dma: Probing channel failed
   [    2.064990] xilinx-zynqmp-dma: probe of ffac0000.dma failed with error -2
   [    2.065053] xilinx-zynqmp-dma ffad0000.dma: main clock not found.
   [    2.065069] xilinx-zynqmp-dma ffad0000.dma: Probing channel failed
   [    2.065090] xilinx-zynqmp-dma: probe of ffad0000.dma failed with error -2
   [    2.065154] xilinx-zynqmp-dma ffae0000.dma: main clock not found.
   [    2.065169] xilinx-zynqmp-dma ffae0000.dma: Probing channel failed
   [    2.065190] xilinx-zynqmp-dma: probe of ffae0000.dma failed with error -2
   [    2.065255] xilinx-zynqmp-dma ffaf0000.dma: main clock not found.
   [    2.065271] xilinx-zynqmp-dma ffaf0000.dma: Probing channel failed
   [    2.065292] xilinx-zynqmp-dma: probe of ffaf0000.dma failed with error -2
   [    2.065376] zynqmp_pm_probe power management API version error. Expected: v0.2 - Found: v0.0
   [    2.065400] zynqmp_pm: probe of firmware failed with error -5
   [    2.065490] xenfs: not registering filesystem on non-xen platform
   [    2.089753] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
   [    2.090961] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 214, base_baud = 6250000) is a xuartps
   [    3.272631] console [ttyPS0] enabled
   [    3.276405] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 215, base_baud = 6250000) is a xuartps
   [    3.286669] [drm] Initialized drm 1.1.0 20060810
   [    3.291611] Unable to detect cache hierarchy from DT for CPU 0
   [    3.302136] brd: module loaded
   [    3.308047] loop: module loaded
   [    3.311838] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
   [    3.320746] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
   [    3.331119] scsi host0: ahci-ceva
   [    3.334694] scsi host1: ahci-ceva
   [    3.338123] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 210
   [    3.346068] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 210
   [    3.354226] mtdoops: mtd device (mtddev=name/number) must be supplied
   [    3.361337] m25p80 spi32766.0: Controller not in SPI_TX_QUAD mode, just use extended SPI mode
   [    3.369845] m25p80 spi32766.0: n25q256a (65536 Kbytes)
   [    3.374932] 3 ofpart partitions found on MTD device spi32766.0
   [    3.380720] Creating 3 MTD partitions on "spi32766.0":
   [    3.385842] 0x000000000000-0x000000780000 : "qspi-boot"
   [    3.391556] 0x000000780000-0x000000800000 : "qspi-bootenv"
   [    3.397416] 0x000000800000-0x000004000000 : "qspi-linux"
   [    3.404781] libphy: Fixed MDIO Bus: probed
   [    3.409314] CAN device driver interface
   [    3.413939] libphy: MACB_mii_bus: probed
   [    3.651038] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   [    3.657496] ehci-pci: EHCI PCI platform driver
   [    3.662122] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   [    3.667545] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
   [    3.673693] ata2: SATA link down (SStatus 0 SControl 330)
   [    3.673720] ata1: SATA link down (SStatus 0 SControl 330)
   [    3.686162] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x00010010
   [    3.694814] xhci-hcd xhci-hcd.0.auto: irq 219, io mem 0xfe200000
   [    3.700868] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
   [    3.707591] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   [    3.714795] usb usb1: Product: xHCI Host Controller
   [    3.719647] usb usb1: Manufacturer: Linux 4.4.0 xhci-hcd
   [    3.724942] usb usb1: SerialNumber: xhci-hcd.0.auto
   [    3.730090] hub 1-0:1.0: USB hub found
   [    3.733787] hub 1-0:1.0: 1 port detected
   [    3.737796] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   [    3.743211] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
   [    3.750888] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
   [    3.758991] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
   [    3.765708] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   [    3.772915] usb usb2: Product: xHCI Host Controller
   [    3.777768] usb usb2: Manufacturer: Linux 4.4.0 xhci-hcd
   [    3.783063] usb usb2: SerialNumber: xhci-hcd.0.auto
   [    3.788164] hub 2-0:1.0: USB hub found
   [    3.791857] hub 2-0:1.0: 1 port detected
   [    3.795918] usbcore: registered new interface driver uas
   [    3.801224] usbcore: registered new interface driver usb-storage
   [    3.807362] mousedev: PS/2 mouse device common for all mice
   [    3.813230] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
   [    3.820428] i2c /dev entries driver
   [    3.824159] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 205
   [    3.830623] at24 1-0052: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
   [    3.837260] i2c i2c-0: Added multiplexed i2c bus 1
   [    3.842151] i2c i2c-0: Added multiplexed i2c bus 2
   [    3.846866] pca954x 0-0070: registered 2 multiplexed busses for I2C mux pca9542
   [    3.855115] EDAC MC: ECC not enabled
   [    3.858701] sdhci: Secure Digital Host Controller Interface driver
   [    3.864802] sdhci: Copyright(c) Pierre Ossman
   [    3.869145] sdhci-pltfm: SDHCI platform and OF driver helper
   [    3.876017] sdhci-arasan ff160000.sdhci: No vmmc regulator found
   [    3.881948] sdhci-arasan ff160000.sdhci: No vqmmc regulator found
   [    3.929689] mmc0: SDHCI controller on ff160000.sdhci [ff160000.sdhci] using ADMA 64-bit
   [    3.942006] sdhci-arasan ff170000.sdhci: No vmmc regulator found
   [    3.947949] sdhci-arasan ff170000.sdhci: No vqmmc regulator found
   [    4.001688] mmc1: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
   [    4.009803] usbcore: registered new interface driver usbhid
   [    4.015301] usbhid: USB HID core driver
   [    4.019727] Mali: Mali device driver loaded
   [    4.024561] pktgen: Packet Generator for packet performance testing. Version: 2.75
   [    4.032347] Initializing XFRM netlink socket
   [    4.036564] mmc0: MAN_BKOPS_EN bit is not set
   [    4.040919] NET: Registered protocol family 10
   [    4.045760] sit: IPv6 over IPv4 tunneling driver
   [    4.050686] NET: Registered protocol family 17
   [    4.055071] NET: Registered protocol family 15
   [    4.059484] can: controller area network core (rev 20120528 abi 9)
   [    4.065681] NET: Registered protocol family 29
   [    4.070076] can: raw protocol (rev 20120528)
   [    4.074327] can: broadcast manager protocol (rev 20120528 t)
   [    4.079972] can: netlink gateway (rev 20130117) max_hops=1
   [    4.087505] Key type dns_resolver registered
   [    4.092023] registered taskstats version 1
   [    4.097141] Btrfs loaded
   [    4.097265] mmc0: new HS200 MMC card at address 0001
   [    4.097494] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
   [    4.097593] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
   [    4.097707] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
   [    4.097801] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB
   [    4.098627]  mmcblk0: p1
   [    4.129610] rtc_zynqmp ffa60000.rtc: setting system clock to 1970-01-01 00:00:08 UTC (8)
   [    4.137825] ALSA device list:
   [    4.140706]   No soundcards found.
   [    4.150964] Freeing unused kernel memory: 16596K (ffffffc000a35000 - ffffffc001a6a000)
   [    4.158836] Freeing alternatives memory: 52K (ffffffc001a6a000 - ffffffc001a77000)
   [    4.163330] mmc1: new high speed SDHC card at address 0007
   [    4.163572] mmcblk1: mmc1:0007 SD16G 14.4 GiB (ro)
   [    4.165393]  mmcblk1: p1
   INIT: version 2.88 booting
   [    4.389458] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
   [    4.436217] EXT4-fs (mmcblk0rpmb): unable to read superblock
   [    4.442062] EXT4-fs (mmcblk0rpmb): unable to read superblock
   [    4.447835] EXT2-fs (mmcblk0rpmb): error: unable to read superblock
   [    4.454178] FAT-fs (mmcblk0rpmb): unable to read boot sector
   [    4.463810] EXT4-fs (mmcblk0rpmb): unable to read superblock
   [    4.469543] EXT4-fs (mmcblk0rpmb): unable to read superblock
   [    4.475284] EXT2-fs (mmcblk0rpmb): error: unable to read superblock
   [    4.481844] FAT-fs (mmcblk0rpmb): unable to read boot sector
   [    4.487569] FAT-fs (mmcblk0rpmb): unable to read boot sector
   mount: mounting /dev/mmcblk0rpmb on /run/media/mmcblk0rpmb failed: Invalid argument
   mount: mounting /dev/mmcblk0boot0 on /run/media/mmcblk0boot0 failed: Invalid argument
   mount: mounting /dev/mmcblk0boot1 on /run/media/mmcblk0boot1 failed: Invalid argument
   sh: /sys/block/mmcblk0/mmcblk0p1: unknown operand
   mount: mounting /dev/mmcblk0 on /run/media/mmcblk0 failed: Device or resource busy
   Creating /dev/flash/* device nodes
   [    4.616322] random: dd urandom read with 4 bits of entropy available
   Starting internet superserver: inetd.
   INIT: Entering runlevel: 5
   Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device
   Starting Dropbear SSH server: Generating key, this may take a while...
   Public key portion is:
   ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCVAF1Mj3mH3sP04ecCB4kye5DtDNkpEfUHD0qoLCWTEqs6cfSO5CwX5tfjYCDEAT/+EfH7dKHQtLZ3eEEUSeDY3QOBRC1ZqIhwzgfQaNAqmBbVTdWp4GrLSVJWGR7dVvHIV6M6MQ+AmbEHt2anZl50JyFP1T8cU5g2V6a5H2xFyz0dwl2X60ZuVQmKApzOD14/zhfsvjDRUXuRO/RtpOJJr7qibEVy8mxasJY6TBwvJJDwswwClwjWiMv+UPkrdKNMvT+gb4T1W94Y9BxHtVWj0H1wfPSR1UaQAmQot5f83FBtdKOmXytgZu/DQsCz/F0quq0MxEG2khFI7W13xlyJ root@uz3eg-2016-2
   Fingerprint: md5 8b:4c:9c:2d:2a:3c:50:35:20:3a:ce:f3:f8:74:97:d6
   dropbear.
   starting Busybox HTTP Daemon: httpd... done.
   ***   Avnet UltraZed Out Of Box PetaLinux Build V1.0              ***
   ***   Based Upon the UZ3EG 2016.2 PetaLinux BSP from Avnet        ***
   ***   More information available on UltraZed.org community site   ***
   uz3eg-2016-2 login: root
   Password:
   login[1865]: root login on 'ttyPS0'
   root@uz3eg-2016-2:~#
   root@uz3eg-2016-2:~# ipconfig -a
   -sh: ipconfig: not found
   root@uz3eg-2016-2:~# ifconfig -a
   lo        Link encap:Local Loopback
             inet addr:127.0.0.1  Mask:255.0.0.0
             inet6 addr: ::1/128 Scope:Host
             UP LOOPBACK RUNNING  MTU:65536  Metric:1
             RX packets:0 errors:0 dropped:0 overruns:0 frame:0
             TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
             collisions:0 txqueuelen:0
             RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
   sit0      Link encap:IPv6-in-IPv4
             NOARP  MTU:1480  Metric:1
  • tarekeldeeb
    0 tarekeldeeb over 8 years ago
    Anybody from the zedboard support team? This is a blocking issue for me.
  • narrucmot
    0 narrucmot over 8 years ago
    Is this for the UltraZed-EG I/O or PCIe Carrier?  In any case this is an old PetaLinux image from 2016.  If my memory is correct we made a change to the MDIO PHY address on the SOM, and so if you are trying to boot this 2016.2 image on a current production rev SOM, it does not surprise me that Ethernet doesn't work.  A quick solution would be to boot a current PetaLinux 2018.2 BSP:
    I/O Carrier:
    http://www.ultrazed.org/support/design/17596/131
    PCIe Carrier:
    http://www.ultrazed.org/support/design/17956/141
    Instructions for installing the BSPs can be found in Xilinx UG1144, Chapter 3:
    http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1144-petalinux-tools-reference-guide.pdf
    Cheers,
    Tom
