Ultrazed Hardware Design UZ3EG - DisplayPort - Petalinux/Vivado 2018.2
  • Replies 7 replies
  • Subscribers 362 subscribers
  • Views 841 views
vcouvert
vcouvert over 8 years ago
Hi all,
DisplayPort worked on our UZ3EG based board when using Petalinux/Vivado 2016.4.
Now we try to switch to 2018.2 version but DisplayPort no more works. When having a look at Linux boot log, I found a mesage saying "failed to configure link values" and "failed to train DP link".
Any idea on how to fix it?
Thanks.
  • jafoste4
    0 jafoste4 over 8 years ago
    Did you rebuild it from scratch or just open the same project in 2018.2 and update IPs?
    Please try rebuilding it from scratch.
    Josh
  • sonictai
    0 sonictai over 8 years ago
    Hello Josh,
    I'll answer for Vincent who's in vacation right now!!
    There was an error in the Vivado PS configuration, dealing with the reference clock for the DisplayPort (actually when I upgraded my VIVADO projet from 2016.4 to 2018.2 I had to recreate all the PS by hand because the tool didn't want to do it...so I forgot these reference clokcs).
    Now it works!
    Thank you, Christophe
  • jafoste4
    Hello Christophe,
    Im glad you found the solution, thank you for sharing!
    --Josh
    0 e14 Contributor over 8 years ago
    Hello Vincent,
    Could you please mention the FPGA design (reference desing) and petalinux BSP you used in order to work with Display Port?
    Thanks in advance.
    Ron.
  • sonictai
    Hello shpasser,
    We began our work on the DisplayPort at the early beginning of the Ultrazed with no real reference design so we spent a lot of time trying, reading ZCU102 documents, the DisplayPort standard, changing the device tree, playing witht an EDID editor, etc etc. We were in 2016.4.
    From the hardware point of view we have a clock wizard feeding a 154MHz to the dp_video_in_clk.
    From the LINUX point of view I'll let Vincent answer you!
    Christophe
  • vcouvert
    0 vcouvert over 8 years ago in reply to e14 Contributor
    Hi Ron,
    We created a Petalinux project from scratch for our Ultrazed-3EG SOM without using a packaged BSP.
    After Christophe modifications on design, I just had to modify generated device tree to use our clock wizard generated clock for dp_live_video_in_clk and it worked.
    This support AR was useful too: https://www.xilinx.com/support/answers/69764.html
    Vincent
    Thanks a lot for the answers.
    Ron.
