Ultrazed Hardware Design Out of the Box UltraZed-EG not working
  • Replies 27 replies
  • Subscribers 366 subscribers
  • Views 3162 views
dramoz
dramoz over 9 years ago
Hi.
I just got the UltraZed board, but the Out of the Box is not working.
When powered, only the Vin HDR led is turned on. Also, the fan is not working. All other LEDs are off.
Danilo.
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Dramoz,
    We suspect there is an issue with the PMIC on the IO Carrier Card. Please refer to your private messages on the top right hand corner of this webpage to discuss how we would like to fix this issue.
    --Josh
  • bobtek
    0 bobtek over 9 years ago
    Received the starter kit today and seem to have the same problem.
    Bob
  • jafoste4
    Hello Bobtek,
    Please refer to your private messages as well. I will provide you with details on how we plan to remedy your issue.
    --Josh
  • jamestkennedy
    0 jamestkennedy over 9 years ago
    recieved ultrazed kit and mine functions with the same problems as the other 2 on this thread.
    please help ASAP.
    James
  • jafoste4
    Hello James,
    Please refer to this forum post : http://zedboard.org/content/ultrazed-som-power-regulator-shunt
    --Josh
  • jamestkennedy
    0 jamestkennedy over 9 years ago in reply to jafoste4
    Josh,
    This did not fix the problem presented in this thread.
    Sincerely,
    James
  • jafoste4
    0 jafoste4 over 9 years ago in reply to bobtek
    Bobtek's issue was solved by removing the JP1 shunt from the UltraZed SOM. The solution is highlighted in this forum post: http://zedboard.org/content/ultrazed-som-power-regulator-shunt
    --Josh
  • jafoste4
    Dramoz's issue was solved by removing the JP1 shunt from the UltraZed SOM. The solution is highlighted in this forum post: http://zedboard.org/content/ultrazed-som-power-regulator-shunt
    --Josh
    0 e14 Contributor over 9 years ago in reply to jamestkennedy
    Hi, Did anyone fix this problem?
    I removed JP1 stunt . no change.. only D10 LED gets on. Nothing else working .Can someone help me with this?
    Goutham
  • jafoste4
    0 jafoste4 over 9 years ago in reply to e14 Contributor
    Hello Gouthman,
    Just to double check, your removed the JP1 shunt from the SOM and not the IO Carrier Card correct? Also you are using the Power Supply that came with your development kit correct?
    --Josh
