Ultrazed Hardware Design UltraZed-EV compatibility with UltraZed-EG PCIe Carrier Card
  • Subscribers 359 subscribers
  • Views 738 views
e14 Contributor over 8 years ago
Is the Ultrazed-EV compatible with the Ultrazed-EG PCIe Carrier Card?
  • jafoste4
    0 jafoste4 over 8 years ago
    Unfortunalty no it is not. At this time the only carrier card we offer that works with the UltraZed EV is http://zedboard.org/product/ultrazed-ev-carrier-card
    Please note, this board also has an FMC available to it.
    -Josh
  • drozwood90
    0 drozwood90 over 8 years ago
    If you need to use the UltraZed-EV as a end node vs a root for PCIe, might I suggest a female to female cable from Samtech?  Or even a cable that will take the SMA to PCie?
    We have some customers that have had success with this in the past on other systems.
    --Dan
