Ultrazed Hardware Design UltraZed DDR4
  • Subscribers 359 subscribers
  • Views 529 views
UltraZed DDR4
gge7
gge7 over 9 years ago
Hello
Thank you again for your time.
Again reviewing the UltraZed SOM schematic and Hardware Design Guide I wanted to find out if when you laid out the DDR4 did your compensate for the pin package flight delays in the Micron DDR?  I know you stated you did for the Zynq UltraScale+ Package but not sure about the DDR4 RAM?
If you did, did you calculate the flight delay times from the IBIS model using Xilinx's AR34174 method where by you use the SQRT of L*C of each pin shown in the IBIS model?  Would that be a valid way?
Thank you again,
Gary
  • jafoste4
    0 jafoste4 over 9 years ago
    Hello Gary,
    QUESTION 1 -  Again reviewing the UltraZed SOM schematic and Hardware Design Guide I wanted to find out if when you laid out the DDR4 did your compensate for the pin package flight delays in the Micron DDR?  I know you stated you did for the Zynq UltraScale+ Package but not sure about the DDR4 RAM?
    ANSWER - The DDR4 RAM package delay was not removed from the design. With that said, one could feasibly attempt to extract that data from the IBIS model, but it was shown during the prototype phase that the DDR4 implementation at the maximum performance of the MPSoC passed stress tests provided to Avnet by Xilinx.
    QUESTION 2 - If you did, did you calculate the flight delay times from the IBIS model using Xilinx's AR34174 method where by you use the SQRT of L*C of each pin shown in the IBIS model?  Would that be a valid way?
    ANSWER - We did not include the DDR4 package delay in the interface calculation.
