Ultrazed Hardware Design re-flash with pre-built image does not boot
  • Subscribers 359 subscribers
  • Views 712 views
  • ultrazed-ev
  • pre-built
cb_cross
cb_cross over 7 years ago
I have tried to flash the QSPI with an image that will boot from TFTP.  It didn't work.
So, I re-flashed with the pre-built image using these settings:
I inadvertently flashed with "uz_petalinux_hw" as the platform before this attempt.  Both attempts get the same result:  "Xilinx Zynq MP First S" plus a non-printable character repeated 8 times in the terminal window when I try to boot with the boot mode switches set to QSPI32.  If I set the boot mode switches to QSPI24, the sequence repeats only once.
I was able to re-flash the pre-built image successfully before.  I'm scratching my head to try and figure out what's different.
I have tried with both qspi_single and qspi_dual_parallel, it doesn't make a difference in the result, nor with the speed of the flash process.
Yes, I have the boot mode switch set to JTAG during the flash process.
  • cb_cross
    0 cb_cross over 7 years ago
    Not sure why it made a difference, but at the suggestion of my local FAE, I flashed the pre-built image from the uz7ev_evcc_2018_2 BSP and it worked.
