Ultrazed Hardware Design Network FMC Module compatibility with KC705
  • Subscribers 360 subscribers
  • Views 1254 views
  • ultrazed-ev
  • kintex-7
  • xilinx
  • network
  • fmc carrier card
  • compatibility
andcre-avnet
andcre-avnet over 7 years ago
Hello all,I've seen from the Quick Start Reference Guide of the Network FMC that they suggest to use the UltraZed-3EG in conjunction with the UltraZedEG PCIe Carrier Card.
But I would like to know if AES-FMC-NETW1-G is compatible with Xilinx Kintex-7 FPGA KC705 board .
Thanks in advance for your help.
Best regards,
Andrea
  • jafoste4
    jafoste4 over 7 years ago +1 verified
    Hi Andrea, The AES-FMC-NETW1-G should be compatible with the KC705. The KC705 board has a LPC and HPC FMC connector, the LPC FMC connector on the AES-FMC-NETW1-G is compatible with both. The VADJ levels…
  • jafoste4
    0 jafoste4 over 7 years ago
    Hi Andrea,
    The AES-FMC-NETW1-G should be compatible with the KC705. The KC705 board has a LPC and HPC FMC connector, the LPC FMC connector on the AES-FMC-NETW1-G is compatible with both. The VADJ levels on the KC705 should also work with the Network FMC.
    Unfortunately the only platform we are able to support from a development perspective is the UltraZed platform with the Network FMC at this time.
    -Josh
  • andcre-avnet
    0 andcre-avnet over 7 years ago in reply to jafoste4
    Thanks for the answer.
    Andrea
