Ultrazed Hardware Design How do I flash the PL user leds on an Ultrazed 3EG SOM with IOCC?
  • Subscribers 360 subscribers
  • Views 773 views
bbaumberger
bbaumberger over 7 years ago
  • jafoste4
    0 jafoste4 over 7 years ago
    Can you please elaborate on your question? You want to blink PL LEDs?
    Take a look at this.
    https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Blinking-LED-with-Xilinx-Zynq-Ultrascale/td-p/890500
    It
    --Josh
  • bbaumberger
    0 bbaumberger over 7 years ago in reply to jafoste4
    Thanks Josh. I'm looking at it from a much lower (register) level...
    Here's the procedure I use to turn on the PS User LED on MIO_31:
    data              address    function
    0xffdf0000 0xff0a0008  write32    ; select and turn off MIO_31 in MASK_DATA_1_LSW
    0x00000020 0xff0a0244 write32 ; select MIO_31 as an output in DIRM_1
    0x00000020 0xff0a0248 write32 ; enable MIO_31 output in OEN_1
    0xffdf0020 0xff0a0008 write32 ;  select and turn on MIO_31 in MASK_DATA_1_LSW
    This works. I guess my question is: how do I tell which signal/register is mapped to the PL User LEDs?
  • jafoste4
    0 jafoste4 over 7 years ago in reply to bbaumberger
    Hi Brett,
    From my understanding your accessing the leds currently via MIO pins using the PS.
    To do the same for the PL you can use an axi gpio block and route the signals to the leds using a constraints file. Once you add the axi gpio block it will define an address within vivado.
    Is this more along the lines of what you are asking?
    Thx,
    Josh
