Ultrazed Hardware Design When will be released petalinux 2019.1 BSP  for Ultrazed-EV carrier card?
  • Replies 9 replies
  • Answers 4 answers
  • Subscribers 362 subscribers
  • Views 1421 views
pierlum
pierlum over 7 years ago
when will be released petalinux 2019.1 BSP  for Ultrazed-EV carrier card?
Thank you very much.
  • jafoste4
    jafoste4 over 7 years ago in reply to jlesquer +2 suggested
    Hi Jose, Unfortunately I wouldn't expect to have a 2019.1 BSP for the UltraZed-Ev kit available until late August. -Josh
  • jafoste4
    jafoste4 over 7 years ago +1 suggested
    Hi, As of now, we are targeting the end of July or early August. -Josh
  • jafoste4
    jafoste4 over 7 years ago in reply to pierlum +1 suggested
    Hi, There is no further update at this time. -Josh
  • jafoste4
    0 jafoste4 over 7 years ago
    -Josh
  • pierlum
    0 pierlum over 7 years ago in reply to jafoste4
    thank you very much. Is there any update about the release date? Thanks.
  • jafoste4
    0 jafoste4 over 7 years ago in reply to pierlum
    -Josh
  • pierlum
    thank you very much for the quick reply.
  • jlesquer
    0 jlesquer over 7 years ago in reply to jafoste4
    We're currently working with Ultrazed-EV dev kit and working with 2018.2BSP, the problem is that with this version there's not good support for Mem2Mem xilinx framework using V4L2 driver and for e.g some video capabilities are not working properly. All of this is fixed for 2019.1. Our plan is to use this board for our video applications so to have a 2019.1BSP option would be very convenient....
    Is there any update on when the 2019.1 bsp would be ready?
    Many thanks.
  • jafoste4
    0 jafoste4 over 7 years ago in reply to jlesquer
    Hi Jose,
    -Josh
  • jlesquer
    Hi Josh,
    Thanks for the update, then it would be great to have it for late August.
    Best regards.
  • 100padudle
    0 100padudle over 7 years ago in reply to jlesquer
    It is mid August. Is there an update on the 2019.1 BSP for the Ultrazed EG on the IO carrier card?  We really need it.
  • drozwood90
    0 drozwood90 over 7 years ago in reply to 100padudle
    Hi there,
    I'm sorry that we have not been able to work on this at this time.
    Our resources have been tied up on other projects.  We suggest that you take a look at building your own BSP
    https://github.com/Avnet/petalinux
    This is the repository that is used to support our automated builds under PetaLinux tools that use Yocto
    We have scripts that show how we did it for older PetaLinux versions
    You can also follow UG1144 to help guide you:
    https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1144-petalinux-tools-reference-guide.pdf
    --Dan
