Ultrazed Hardware Design FMC Mezzanine Card/ Breakout Board
  • Subscribers 359 subscribers
  • Views 2179 views
  • fmc
  • fmc_hpc
marshall_curry
marshall_curry over 7 years ago
I am using the UltraZed-EV Carrier Card (AES-ZUEV-CC-G) and am trying to access GPIO via the FMC HPC Interface. Do you recommend a pre-built FMC Mezzanine Card/ Breakout Board to use with this?
The product description/ number of the FMC connector on the carrier card is as follows and the Carrier Card Schematic and BOM is attached:
Connector Name on Carrier Card: JX4
Connector Description: CONN, VITA 57 FMC, RCPT, 400POS, 10ROW
Manufacturer: Samtec
Manufacturer Part Number: SEAF-40-06.5-S-10-2-A-K-TR
Thank you!
Marshall
imagePRJ-US3CAR-1-01-02-Schematic-Prints.pdf
imagePRJ-US3CAR-1-01-0-Marketing-BOM-scxlsx.pdf
  • drozwood90
    drozwood90 over 7 years ago +1 suggested
    Marshall, This is a standard FMC, so you can use any card that uses the FMC HPC or FMC LPC standard. If you choose a FMC LPC, you will lose access to some of the possible IO. Please check schematics prior…
  • marshall_curry
    marshall_curry over 7 years ago in reply to drozwood90 +1
    Thank you Dan. I am considering the FMC XM105 Debug Card ( HW-FMC-XM105-G). Best Regards, Marshall
  • drozwood90
    drozwood90 over 7 years ago in reply to marshall_curry +1
    Marshall, I don't see a problem with that. I've used that on previous products with much less capability than an UltraZed. --Dan
  • drozwood90
    0 drozwood90 over 7 years ago
    Marshall,
    This is a standard FMC, so you can use any card that uses the FMC HPC or FMC LPC standard.  If you choose a FMC LPC, you will lose access to some of the possible IO.  Please check schematics prior to using to ensure the FMC LPC will suit your needs.
    --Dan
  • marshall_curry
    0 marshall_curry over 7 years ago in reply to drozwood90
    Thank you Dan.
    I am considering the FMC XM105 Debug Card (HW-FMC-XM105-G).
    Best Regards,
    Marshall
  • drozwood90
    0 drozwood90 over 7 years ago in reply to marshall_curry
    Marshall,
    --Dan
  • marshall_curry
    I appreciate your help. I couldn't find too many other FMC HPC Breakout Boards available. I am glad this one is available. Do you have any others you would recommend?
    Thank you,
    Marshall
