Ultrazed Hardware Design Ultrazed-EV: How to test the SFP cages with copper network cable?
  • Subscribers 359 subscribers
  • Views 929 views
  • test
  • ultrazed-ev
  • sfp+
  • gth
  • xilinx
  • Reference Design
deville
deville over 7 years ago
Hi Avnet,
At the moment i'm about to test the SFP cages with a Dell 470-13571 Networking SFP+ cable.
How can I test these ports? i've noticed they are connected to the PL side on the GTH bus ( H1 & H2)
Do you have some reference applications available? The manual is very limited on the subject.
Thanks Avnet,
Deville
  • deville
    deville over 7 years ago in reply to drozwood90 +2
    Hi Dan, Thanks for your answer. I'll look it up.. Is this design something you can share or release? Just for reference? On our own board design we don't connect the cages to the PL side so a full implementation…
  • drozwood90
    drozwood90 over 7 years ago in reply to deville +2 verified
    Deville, The design is built into Vivado. We have a build script for a different board that would generate the design, but really it is not very hard to do. If you take a look at our PicoZed page: http…
  • deville
    Hi Dan , Thanks for pointing me in the right direction. I'll give it a try Kind regards Deville
  • drozwood90
    0 drozwood90 over 7 years ago
    Hi there,
    We use the Vivado built in IBERT test for this.  If you need to test something else, you would need to implement something based on the design you are attempting to replicate / use.
    --Dan
  • deville
    0 deville over 7 years ago in reply to drozwood90
    Hi Dan,
    On our own board design we don't connect the cages to the PL side so a full implementation is a bit overkill.  We are waiting on our own custom assembled PCB so in the meantime I wanted to perform simple tests for future reference.
    Thanks again Dan
    Deville
  • drozwood90
    0 drozwood90 over 7 years ago in reply to deville
    Deville,
    http://picozed.org/support/design/13076/106
    All the way at the bottom, you will see an IBERT design.  That should give you the steps to set it up.
    Just make sure you substitute for the 7EV MPSoC as well as the other appropriate settings!
    I feel confident that once you see the flow as well as get into the GITHUB files, you'll see what needs to be done.
    You can also check out our Tech Tips videos on tuning.  There are a few features that MPSoC has that the PicoZed does not, but there is still a LOT of good content in there to help you work through the tuning process.
    http://avnet.me/TransceiverTechTips
    --Dan
  • deville
    Hi Dan ,
    Kind regards
    Deville
