Ultrazed Hardware Design avnet ultrazed pcie board phy setting in device tree
  • Subscribers 360 subscribers
  • Views 1398 views
  • pcie carrier card
  • ethernet phy
  • ultrazed-eg
  • pcie carrier
aaydogmus
aaydogmus over 7 years ago
hi i am started to discover avnet ultrazed-eg pcie carrier board but neither my petalinux build or out of the box image connecting to ethernet, is there anything that i can configure over device tree?
as I understand I should give phy entry to &gem3, but my tryings are not succeed.
  • jafoste4
    0 jafoste4 over 7 years ago
    Are you using one of the provided bsps?
    -Josh
  • aaydogmus
    0 aaydogmus over 7 years ago in reply to jafoste4
    hi,
    i am using a hdf file for my petalinux project that is generated from vivado, it has leds and switchs only, gem3 is also enabled (i did not changed anything).
  • jafoste4
    0 jafoste4 over 7 years ago in reply to aaydogmus
    Hi Abdulaziz,
    I dug into one of our BSPs and this is how we defined it in the system-user.dtsi
    &gem3 {
    status = "okay";
    local-mac-address = [00 0a 35 00 02 90];
    phy-mode = "rgmii-id";
    phy-handle = <&phy0>;
    phy0: phy@9 {
    reg = <0x9>;
    ti,rx-internal-delay = <0x5>;
    ti,tx-internal-delay = <0x5>;
    ti,fifo-depth = <0x1>;
    -Josh
  • aaydogmus
    thanks it worked,
    is there any further information how we get this result? That would be great
  • jafoste4
    I unzipped the latest BSP we have for this board and looked in the system-user-dtsi file. Is that what your looking?
    -Josh
