Ultrazed Hardware Design how to tie off unused USB on UltraZed carrier board?
  • Subscribers 358 subscribers
  • Views 746 views
  • ultrazed
  • usb
hdw
hdw over 6 years ago
I'm designing a custom carrier board for the UltraZed EG SOM.  I am not using the USB interface.  Do any of the USB signals (ID, OTG, CPEN, DM/DP) need to be pulled up or down or otherwise connected on the carrier board?
  • drozwood90
    0 drozwood90 over 6 years ago
    Hi there,
    They come from the USB PHY.  Microchip USB3320.  You should read through that datasheet to ensure you understand the part and if there is anything special you would need to do in the case of what you are doing / not doing with it.
    As for the GTRs, you can see in Table 4-2 of UG583 UltraScale Architecture PCB Design User Guide (page 192) will provide proper instruction for the GTRs:
    https://www.xilinx.com/support/documentation/user_guides/ug583-ultrascale-pcb-design.pdf
    --Dan
