Ultrazed Hardware Design Avnet Voucher - ultrazed starter
  • Subscribers 360 subscribers
  • Views 1389 views
  • software voucher
  • aes-zu3eg-1-som
  • avnet_zed
  • ultrazed-eg-iocc
gabe6295
gabe6295 over 6 years ago
Hello, I received an Avnet Ultra zed Starter board with a sheet that indicates a software voucher.
However, after examining the box the board came in there was no voucher inside.
I contacted Avnet and they directed me to this community to ask the question.
Here are the part number of the boards I received.
p/n: AES-ZU3EG-1-SOM-I-G UltraZed-EG SOM - Zynq UltraSCALE 3EG based
p/n: AES-ZU-IOCC-G UltraZed-EG IO Carrier Card
Please let me know if you can provide an answer.
Thank you for the support.
-Gabe
  • Andrew J
    0 Andrew J over 6 years ago
    Did you check on the SD card for software?  That’s the only reference I can find to software, from the Ultrazed site http://www.ultrazed.org/support/design/14201/126. No vouchers are mentioned on the Avnet product page or “what’s included” list.  It may help to be more specific about the “sheet” you refer to.  Sometimes suppliers change the way they bundle things but don’t change the packaging which then becomes confusing.
  • gabe6295
    0 gabe6295 over 6 years ago in reply to Andrew J
    Hi Andrew,
    Sorry about that I should have included the sheet that states there is a voucher in the box. Everywhere I look state the number is in the box, but I have had no luck finding it.
    I checked all the labels on the box, the board itself, and the sheet below, which is the only sheet in the box. Am I missing anything?
    Thanks again for the help!
  • Andrew J
    0 Andrew J over 6 years ago in reply to gabe6295
    This thread implies they aren't selling ES1 silicon boards anymore so there won't be a voucher, you have to use the freely licensed Vivado webpack:
    https://www.element14.com/community/thread/71564/l/questions-about-the-ultrazed-eg-and-licensing
    However, I'm no expert.  Here's someone with a similar issue but from 2017 (when they were selling ES1) - try posting in the same board as you may get a quicker/a response there.
    https://www.element14.com/community/thread/68411/l/es1-silicon-license
    The alternative is to point you at the SD card - you're sure there isn't a voucher file on there?  That would be the simplest way to ship it rather than a printed sheet.
    Sorry it's not more positive from me but it does appear that you don't get a voucher and it looks like I was right in my first post: they've changed the bundling but not updated the packaging.
  • gabe6295
    I did check the SD card and only a bootable image is on file as of now.
    You are probably right. Looking into the other threads you provided, it appears they did not update their print.
    I saw a post in March of 2020 for an UlatraZed-EV that looked like they recieved a voucher, and assumed I should have recieved one as well.
    https://www.element14.com/community/message/289271/l/re-voucher-ultrazed-ev#289271
    However, the EG is the one with the ES1 silicon. Thank you for pointing that out.
    Thank you again for the help!
