Ultrazed Hardware Design UltraZed I-Grade potential Issue
  • Subscribers 358 subscribers
  • Views 1532 views
  • ultrazed-ev
  • ultrazed
  • ultrazed-eg
  • aes-zu3eg-1-som-i-g
  • som
c_chil
c_chil over 4 years ago
It was brought to Avnet's attention that the UltraZed EG I-Grade, and potentially the EV I-Grade, SOM may experience a failure at temperatures above 75c if the user carrier card is supplying +12V to +VIN pin.
We are currently investigating the primary PMIC capacitors for overvoltage failures and working on a solution.  For now, we recommend reducing the +VIN voltage to 11V or lower if operating the Ultrazed SOM at or above 75c.  We are working to understand the scope of the issue and will notify users of our findings.
  • c_chil
    c_chil over 4 years ago in reply to bhfletcher +1
    Hi bhfletcher, thank you for asking. The C-Grade is not affected by this issue only the I-Grade SOMs when operating at or above 75c. This chart demonstrates the derating that needs to be taken into consideration…
  • bhfletcher
    bhfletcher over 4 years ago
    Hi c_chil -- you don't mention the C-grade UltraZeds. Are they affected?
  • c_chil
    Hi bhfletcher, thank you for asking.  The C-Grade is not affected by this issue only the I-Grade SOMs when operating at or above 75c. This chart demonstrates the derating that needs to be taken into consideration.  The capacitors are rated for 16V so at 85c the max VIN is 11.2V.
  • bhfletcher
    bhfletcher over 4 years ago in reply to c_chil
    Thanks, c_chil. So, just to be clear, all of the following situations are expected to operate without issue, correct?
    • UltraZed-EG/EV C-grade under C-grade conditions
    • UltraZed-EG/EV I-grade with VIN=5V @ 85C
    • UltraZed-EG/EV I-grade with VIN=12 <75C
    This one is the issue:
    • UltraZed-EG/EV I-grade with VIN=12V AND Temp>75C
    Please keep us posted on how your testing works out!
    Bryan
