Ultrazed Hardware Design USB 3.0 support on ultrazed 7ev board petalinux 2020.2
  • Subscribers 359 subscribers
  • Views 1395 views
  • ultrazed-ev
  • usb3
  • 7ev
kumakichi
kumakichi over 4 years ago
Hi there,
We have a design implemented on ultrazed 7v board,
and we found usb 3.0 is not working.
# both usb2.0 and usb 3.0 hub can be found,
but when we insert usb memory, it is always mounted as an usb 2.0 device( new high speed device founded)
Problem is that beside the design we implemented,
we also tried the xsa inside
uz7ev_evcc_base_2020_2.tar.gz
https://avtinc.sharepoint.com/teams/ET-Downloads/Shared%20Documents/Forms/AllItems.aspx?id=%2Fteams%2FET%2DDownloads%2FShared%20Documents%2Fprojects%2Fpublic%5Frelease&p=true&ga=1
but got no luck there
We even compare the device tree of
Out of Box Designs
UltraZed Out of Box Designs
and the one above(uz7ev_evcc_base_2020_2)
nothing is specially different between the configurtation of the device tree.
We also checked the dwc3 status in the debugfs, found that
1.Firmware that we built(USB3 not working):
 [root@uz7ev-evcc-base-2020-2 fe200000.dwc3]$ cat ./link_state
 Not available
2.Firware that comes with the som(Ultrazed 7ev in emmc),[USB3 working]
 [root@uz7ev-evcc-base-2017 fe200000.dwc3]$ cat ./link_state
U0
I actually posted the same question in Xilinx forum but no one replys...
https://support.xilinx.com/s/question/0D52E000076tGbHSAU/usb-30-is-not-working-on-ultrazed-ev-board?language=en_US
If you know anything insufficient in  what we have done please kindly contact me,
Thank you in advance for your help.
kuma
  • kumakichi
    Additional Information:
    Somehow managed to get the dts fille from the emmc firmware(USB 3.0 fine)
    and the one we made to test the usb 3.0(not working)
    		#NotWorking
    		usb0@ff9d0000 {
    			#address-cells = <0x2>;
    			#size-cells = <0x2>;
    			status = "okay";
    			compatible = "xlnx,zynqmp-dwc3";
    			reg = <0x0 0xff9d0000 0x0 0x100>;
    			clock-names = "bus_clk", "ref_clk";
    			power-domains = <0xc 0x16>;
    			ranges;
    			nvmem-cells = <0x11>;
    			nvmem-cell-names = "soc_revision";
    			clocks = <0x3 0x20 0x3 0x22>;
    			xlnx,tz-nonsecure = <0x1>;
    			xlnx,usb-polarity = <0x0>;
    			xlnx,usb-reset-mode = <0x0>;
    			phandle = <0x6a>;
    			dwc3@fe200000 {
    				compatible = "snps,dwc3";
    				status = "okay";
    				reg = <0x0 0xfe200000 0x0 0x40000>;
    				interrupt-parent = <0x4>;
    				interrupt-names = "dwc_usb3", "otg", "hiber";
    				interrupts = <0x0 0x41 0x4 0x0 0x45 0x4 0x0 0x4b 0x4>;
    				#stream-id-cells = <0x1>;
    				iommus = <0xd 0x860>;
    				snps,quirk-frame-length-adjustment = <0x20>;
    				snps,refclk_fladj;
    				snps,enable_guctl1_resume_quirk;
    				snps,enable_guctl1_ipd_quirk;
    				snps,xhci-stream-quirk;
    				dr_mode = "host";
    				phy-names = "usb3-phy";
    				snps,usb3_lpm_capable;
    				phys = <0x13 0x4 0x0 0x2 0x18cba80>;
    				maximum-speed = "super-speed";
    				phandle = <0x6b>;
    From Working EMMC
    		usb0@ff9d0000 {
    			#address-cells = <0x02>;
    			#size-cells = <0x02>;
    			status = "okay";
    			reg = <0x00 0xff9d0000 0x00 0x100>;
    			clock-names = "bus_clk\0ref_clk";
    			power-domains = <0x2c>;
    			ranges;
    			nvmem-cells = <0x1f>;
    			clocks = <0x03 0x20 0x03 0x22>;
    			xlnx,usb-reset = <0x2faf080>;
    			dwc3@fe200000 {
    				status = "okay";
    				reg = <0x00 0xfe200000 0x00 0x40000>;
    				interrupt-parent = <0x04>;
    				interrupts = <0x00 0x41 0x04 0x00 0x45 0x04>;
    				#stream-id-cells = <0x01>;
    				iommus = <0x0e 0x860>;
    				snps,refclk_fladj;
    				dr_mode = "host";
    				phys = <0x2d 0x04 0x00 0x02 0x3197500>;
