Ultrazed Hardware Design UltraZed SATA Performance Test
  • Subscribers 359 subscribers
  • Views 1163 views
dat63
dat63 over 4 years ago
I downloaded the UltraZed_SATA_Performance_Test_Tutorial_PLNX2017_4 and tested with my UltraZed-EV SOM and related Carrier Card. Petalinux correctly detects the disk attached as /dev/sda1 and the SATA I/F is up and running:
SATA link up 6.0 Gbps (SStatus 133 SControl 330)
Nevertheless every test fails while mounting the disk:
mounting /dev/sda1 on /mnt/sda1 failed:Invalid argument
I have tried with different disks but the result is always the same
Any help will be highly appreciated
Thank you
Daniele
  • narrucmot
    0 narrucmot over 4 years ago
    This blog post is for a later version of PetaLinux, but it might provide a clue:
    /technologies/fpga-group/b/blog/posts/fixing-sata-for-the-ultrazeds
    You might also want to try a more recent PetaLinux BSP for the UltraZed.  You can find the BSPs at https://avnet.me/zedupport.
    --Tom
  • dat63
    0 dat63 over 4 years ago in reply to narrucmot
    I followed your suggestion to try a newer Petalinux BSP. I first tried with BSP 2020.1 (prebuilt image) and the system was not even able to boot. I get a kernel panic at a certain point of linux loading but maybe this will be a topic for another post. Finally I tried BSP 2019.2 and I eventually managed to make the disk visible and mountable under linux.
    Thanks for the support
    Daniele
