Ultrazed Hardware Design Ultrazed-EG IOCC stopped at u-boot
  • Subscribers 358 subscribers
  • Views 578 views
  • petalinux
  • ultrazed-eg
  • ultrazed-eg-iocc
100yogesh
100yogesh over 3 years ago
I am new to petalinux and ultrzed-EG IOCC module. I am trying to bring up the petalinux and did not succeed yet.
What did I do?
1. Created xsa file from vivado 2021.2 using the AVNET board presets
2. petalinux-build and created the necessary files and BOOT.bin using the petalinux-package --boot command. Here i specified all the files like, u-boot, dtb, pmufw, atf, image.ub and boot script boot.src.
3. While package i got an error saying the previous section overruns the current so had to use the --offset 0xF40000. With this i am able to package the BOOT.bin. But i am not sure how this works.
4. Formatted the sd-card: Installing Ubuntu on Xilinx ZYNQ-7000 AP SoC Using PetaLinux | by Chathura Rajapaksha | Developments and Implementations on ZYNQ-7000 AP SoC | Medium
  • Select the SD card in gparted
  • Make sure its unmounted and delete the partition of the SD card so that it displays ‘unallocated’ in gparted
  • Right click the unallocated space and create a new partition with following settings, Free Space Proceeding (MiB): 4, New Size (MiB) : 512, File System : FAT32, Label : BOOT. Don’t change other settings and click Add to finish.
  • Right click the remaining unallocated space and create a new partition with following settings, Free Space Proceeding (MiB): 0, Free Space Following(MiB): 0, File System : ext4, Label : rootfs. Don’t change other settings and click Add to finish.
  • Apply all changes to create the partitions.
5. Copied only the BOOT.bin to the BOOT partiotion.
6. Inserted sd-card back into ultrazed and restarted with the uart connected
7. Able to see prints on putty, but eventually halts at u-boot prompt.
Support required:
1. Can anyone help me to understand what i missed.
2. Where can i get information on how the boot, u-boot and offsets work?
3. When dealing with sd-card boot source, what files to copy to what partition.
SERIAL PORT DUMP:
SERIAL PORT DUMP:
Xilinx Zynq MP First Stage Boot Loader
Release 2021.2 Oct 13 2021 - 07:15:53
NOTICE: BL31: v2.4(release):xlnx_rebase_v2.4_2021.1_update1-23-g9188496b9
NOTICE: BL31: Built : 07:41:24, Oct 13 2021
U-Boot 2021.01 (Oct 12 2021 - 09:28:42 +0000)
CPU: ZynqMP
Silicon: v3
Board: Xilinx ZynqMP
DRAM: 2 GiB
usb dr_mode not found
PMUFW: v1.1
EL Level: EL2
Chip ID: zu3eg
NAND: 0 MiB
MMC: mmc@ff160000: 0, mmc@ff170000: 1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Bootmode: SD_MODE1
Reset reason: EXTERNAL
Net:
ZYNQ GEM: ff0e0000, mdio bus ff0e0000, phyaddr -1, interface rgmii-id
No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk mmc@ff160000.blk...
Scanning disk mmc@ff170000.blk...
Found 5 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
JTAG: Trying to boot script at 20000000
## Executing script at 20000000
Wrong image format for "source" command
JTAG: SCRIPT FAILED: continuing...
mmc0(part 0) is current device
Scanning mmc 0:1...
Scanning mmc 1:1...
zynqmp_qspi spi@ff0f0000: Warning: SPI speed fallback to 100 kHz
SF: Detected n25q256ax1 with page size 512 Bytes, erase size 128 KiB, total 64 MiB
device 0 offset 0x3e80000, size 0x80000
SF: 524288 bytes @ 0x3e80000 Read: OK
QSPI: Trying to boot script at 20000000
QSPI: SCRIPT FAILED: continuing...
no devices available
NAND: SCRIPT FAILED: continuing...
starting USB...
No working controllers found
USB is stopped. Please issue 'usb start' first.
starting USB...
scanning bus for devices...
SATA link 0 timeout.
SATA link 1 timeout.
AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
flags: 64bit ncq pm clo only pmp fbss pio slum part ccc apst
Device 0: unknown device
starting USB...
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-zynqmp-zynqmp
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
starting USB...
No ethernet found.
No ethernet found.
ZynqMP>
thanks in advance,
Yogesh
