Ultrazed Hardware Design Non functioning Ultrazed EV clock generator
  • Subscribers 358 subscribers
  • Views 539 views
  • fpga
blindell231
blindell231 8 months ago
Hey all,
I'm in a bit of a pinch with the transceiver reference clock on the Ultrazed EV. As far as I can tell, the device is completely non-functional. This is specifically in reference to the GTH transceiver reference clock generator, IDT 8T49N241-048NLGI (U6).
I have ensured that the quad I am using is mapped to the right reference clock; I am using the clock on pins D9 and D10. I have actually tried all the available reference clocks, but to no avail. I am currently buffering the input with an IBUFDS_GTE4 before passing it to the Ultrascale transceiver wizard.
For debugging purposes, I used the ODIV2 port on the IBUFDS_GTE4, along with a BUFG_GT to bring the clock into the normal fpga fabric for testing. What I found was very strange. When hardwired to an led, the clock toggles the led variably, every 2-8 seconds. When the clock is hooked up to a counter that should roll over around 4 times a second, it never rolls over in a 60 second period.
It appears as though the clock has positive edges in an non-periodic manner, with a half-period of 2-8 seconds. This is confirmed by the fact that a two bit counter rolls over correctly after 8 of these 2-8 second half periods. All of this has been confirmed by the use of the ILA, as well. The clock signal is close to something like:
_____|‾‾‾‾‾‾|___________________|‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾|________|‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾‾|___________|‾‾‾‾‾‾‾‾‾‾‾‾|______________
In that it is not periodic and appears to just toggle randomly.
To me, this is never behavior that I should see from the clock, no matter what the config is. Any thoughts? I'm planning on investigating the warranty solutions, as the board is just over a month old.
  • iksevas
    iksevas 8 months ago +1
    You need to program the clock generator. (+) Ultrazed EV CC problem config 8t49n241 from EEPROM - element14 Community You program the EEPROM from I2C and it configures the programmable clock generator…
  • iksevas
    0 iksevas 8 months ago
    You program the EEPROM from I2C and it configures the programmable clock generator for you.
  • blindell231
    0 blindell231 8 months ago in reply to iksevas
    I thought it had a default configuration? I haven't programmed it yet, the board is almost new
  • dallaspe
    0 dallaspe 8 months ago in reply to iksevas
    Just spent a day tracking down and solving the same issue.  Pretty lame it's not programmed out of the box.  I ended up using the .TXT file from the github link above and programming using J5 and a Digilent Analog Discovery 2.
