Ultrazed Hardware Design where is uz7ev.dtsi?
  • Subscribers 358 subscribers
  • Views 1145 views
  • ultrazed-ev
  • tftpboot
  • petalinux
cb_cross
cb_cross over 7 years ago
Is Avnet working on a DTSI file for the UltraZed boards?
For instance, after creating a PetaLinux project with the Xilinx provided BSP for the ZCU104, there is this file:  xilinx-zcu104-2018.2/components/plnx_workspace/device-tree/device-tree/zcu104-revc.dtsi
That file gets referenced when running `petalinux-config` as:
    * DTG Settings
        ** MACHINE_NAME
            *** zcu104-revc
The UltraZed-EV has no corresponding file after creating a PetaLinux project using the Avnet provided BSP.
I am thinking the lack of this DTSI file is an issue.
I want to TFTP boot my uz7ev board, same as I can do with the ZCU104.
I followed the steps for the uz7ev as I did for the ZCU104, but the BOOT.BIN file I created for the uz7ev file and flashed to it just generates a little bit of garbled text in the terminal window.
  • drozwood90
    drozwood90 over 7 years ago
    Hi there,
    The DTSI files are included in the BSP.  You can also locate all of our DTSI files on our GIT repository.
    https://github.com/Avnet/petalinux/tree/master/configs/device-tree
    After creating a PetaLinux project using the Avnet BSP, you should also be able to locate the DTSI file under /meta-user/recipies-bsp/device-tree/files.
    --Dan
