Ultrazed Hardware Design Ethernet PHY from PL
  • Subscribers 358 subscribers
  • Views 654 views
  • ultrazed-ev
  • ethernet phy
oli669
oli669 over 7 years ago
I have an UltraZed-EV Starter Kit. The documentation states that the Marvell Ethernet PHY included in the SOM is connected to the Zynq PS MIO .
I have a design which includes an AXI TEMAC implemented in the PL, and a I need to connect it to the PHY. It is possible to access that PHY from the PL? If so, how?
  • drozwood90
    drozwood90 over 7 years ago
    The simple answer.  No.
    You would likely have to design something yourself to loop in that direction.  I would NOT suggest that.  It is likely better off to just port the design to use the PS hardened IP.  It will likely save you system resources in the long run as well as be more efficient overall.
    --Dan
