Ultrazed Hardware Design UltraZed PCIe carrier dxf files
  • Subscribers 360 subscribers
  • Views 916 views
  • ultrazed
  • pcie carrier card
  • som
robert.evo
robert.evo over 7 years ago
Is it possible to get a .dxf file of the UltraZed PCIe carrier (PBA-US2CAR-1) showing the following:
  • Board outline
  • mounting holes; PCI bracket, UltraZed, FMC and board (16 total)
  • FMC connector footprint
  • SoM connector footprints
I've tried using "AES-ZU-PCIECC-G-Composite_PCB.pdf" and it's atrocious with no common 0,0 point and most of the dimensions overlap.
Thanks.
  • jafoste4
    jafoste4 over 7 years ago
    Hi Robert,
    If you contact your local avnet fae, he can request the source files for the PCIe Carrier Card for you.
    -Josh
  • robert.evo
    robert.evo over 7 years ago in reply to jafoste4
    Unfortunately this was all sourced long before I joined and anyone who'd know are not available this week. Any suggestions on how I could find this information out?
  • drozwood90
    drozwood90 over 7 years ago in reply to robert.evo
    Robert,
    The only path forward to gain access to source files is to contact your local FAE.  They can make a request upon your behalf, as these are controlled files.
    If you need, I can assist you in looking up your local FAE.  I'm sure there is someone in the office that can assist you.
    --Dan
