ZedBoard Hardware Design XADC - TEMPERATURE.
  • Subscribers 361 subscribers
  • Views 1328 views
XADC - TEMPERATURE.
Hi all, after a while i get to work the XADC. First, works perfectly, but after a while the sensor is reading wrongs values.
Is the XADC crash? or just a calibration problem? someone notice this behavior too ?
Im runing the "xsysmon_polled_printf_example.c" test and i am getting this values:
Thanks a lot.
The Current Temperature is -250.364 Centigrades.
The Maximum Temperature is -250.364 Centigrades.
The Minimum Temperature is -250.471 Centigrades.
The Current VCCINT is 1.601 Volts.
The Maximum VCCINT is 1.601 Volts.
The Minimum VCCINT is 1.598 Volts.
The Current VCCAUX is 2.915 Volts.
The Maximum VCCAUX is 2.916 Volts.
The Minimum VCCAUX is 2.913 Volts.
Exiting the SysMon Polled Example.
    I check the Vref and the others pin in then XADC header and are in the correct values.
    Hi, when I run this test, it warns that there are no pin conenction mentioned, can you guide me on how to correctly implement this tutorial program,
  • 100padudle
    0 100padudle over 9 years ago
    Alfonso,  I have also been getting funny temperature readings from the XADC under Vivado 2016.4.  When I use the hardware manager to just plot the temperature of the Zynq 7020 on a MicroZed board I get those extreme negative temperatures.
    Please post if you find the problem.
