ZedBoard Hardware Design Trimode ethernet mac IP for Zynq
  • Subscribers 359 subscribers
  • Views 848 views
Hi
i have to use  the Tri mode Ethernet MAC Soft IP support on Zed Board.
Though, It is not possible to use this soft IP to configure the Ethernet since the RGMII ports are mapped to MIO pins in Zed board, Only way to configure the Ethernet Hard IP by using PS.
I am wondering if anyone could support me by pointing the reference design for the Ethernet hard IP by using PS.
Any feedback is appreciated.
Thanks and regards
Dineshkumar S
    0 Former Member over 13 years ago
    Hi
    ZynqGeek has a blog post on redirecting MIO pins to the EMIO (he even uses the example of Ethernet MAC).  From this you can drive the ethernet pins using the PL
    http://zedboard.org/content/redirecting-peripherals-mio-emio
    Matthew
    Thanks for your valuable info guys. i will check out the solutions, which you have provided.
    further any clarification, iwill let you know.
    thanks and regards
    Dineshkumar S
    hi
    I have generated the design file in plan ahead by making the Ethernet pin to external and removed the DDR components, other PS IOs.Whether this standalone wrapper can be integrated to enable the Ethernet to work in 1G baud.
