ZedBoard Hardware Design LPC FMC pin out
  • Subscribers 360 subscribers
  • Views 1694 views
LPC FMC pin out
I have seen the pin out in the master constraint file, but I don't understand the connection between the constraint file and the physical pins on the slot. For example, I don't know FMC_LA05_P goes to which pin on the slot. I cant find any reference.
  • metinburak_
    0 metinburak_ over 12 years ago
    When you look at the link http://www.zedboard.org/sites/default/files/documentations/ZedBoard_RevD.2_Schematic_130516.pdf
    you can see the corresponding net names in the FMC connector, the constraint file says that the FMC_LA05_P pin is hardwired to the J18 pin of the zynq device.
    So you should have the schematic also.
    Hello, i am wondering about the FMC-LPC female connector on the zedboard with witch FMC LPC male connector, i found two types of them one 10 mm and the other is 8.5 mm :////
    asp-134604-01
