ZedBoard Hardware Design Axi uart 16550 half duplex
  • Subscribers 358 subscribers
  • Views 289 views
metinburak_
metinburak_ over 11 years ago
I'm using zedboard with Axi 16550 Uart. I want to use this uart in half duplex mode, I'm using Linux from
Analog devices. How can I control the transceiver's Driver enable and receiver enable pins with this uart?
When i look at the RTS and DTR with hardware flow control enable, these pins deassert after very long time the data is transmitted. Can i make a signal just after the stop bit?
Thank you.
  • bhfletcher
    What transceiver are you using and where is it connected?
    Bryan
