ZedBoard Hardware Design Marvell 88E1518 PHY driver
  • Subscribers 359 subscribers
  • Views 1251 views
Hi
I'm in the middle of hacking together a custom linux kernel for the ZED board. It is based on the xilinx kernel sources. So far I succeeded to write a device tree for my own PL modules which seems to do fine. The problem I have now is to get ethernet running. Is there a driver available which supports the 88E1518
phy?
    0 Former Member over 13 years ago
    I'll reply to myself: Apparently the PHY works just fine by using the generic phy driver and a PHY address of 0x0. Here is the Ethernet section of the device tree:
                    eth@e000b000 {
                            compatible = "xlnx,ps7-ethernet-1.00.a";
                            reg = <0xe000b000 0x1000>;
                            interrupts = <0 0x16 0x0>;
                            phy-handle = <&phy0>;
                            xlnx,ptp-enet-clock = <111111111>;
                            xlnx,slcr-div0-1000Mbps = <8>;
                            xlnx,slcr-div0-100Mbps = <8>;
                            xlnx,slcr-div0-10Mbps = <8>;
                            xlnx,slcr-div1-1000Mbps = <1>;
                            xlnx,slcr-div1-100Mbps = <5>;
                            xlnx,slcr-div1-10Mbps = <50>;
                            #address-cells = <0x1>;
                            #size-cells = <0x0>;
                            phy0: phy@7 {
                                    device_type = "ethernet-phy";
                                    reg = <0x0>;
    Going to have a going building an image with angstrom oe
    as there are some fairly decent package repos
    0 Former Member over 13 years ago in reply to Former Member
    whether any initialization needs to configure PHY registers (in non linux)?
