ZedBoard Hardware Design Issue sending data from zedboard to PC via ethernet
  • Subscribers 358 subscribers
  • Views 291 views
Hi all,
      I have been working on Ethernet for quite some time. I am using the TRM and peripheral tests code as reference to send some data to PC. In the peripheral tests code, there is a PHY loop-back enabled. If we disable the loop-back, can we expect the data to go to the RJ-45 directly(I am not able to see any data on PC). I have also changed the destination address as broadcast, even then I am not able to see any packet of data being received in the PC(On Wireshark).
I have tried the lwip echo server, I am getting the ping form the Zedboard.
Can you please help me out with this.
  • bhfletcher
    0 bhfletcher over 12 years ago
    We have examples of transferring data with Linux. Are you trying to do this bare-metal? This is possible with lwip. Have you successfully implemented lwip in your design? It sounds like you have, but can you confirm? Are you successfully pinging between PC and ZedBoard?
    Bryan
